1G AWD sway bar poly bushing
herblove
117
Nov 28, 2002
Danville, Virginia
How in the hell do I get these things to fit. There is no way I can get these to fit in the bracket and rotate over to put in the bolt. WTF. I brought a kit for a 1g AWD and this is the only thing that wont fit.:banghead:
If you can get both sides held up even it's just a matter of getting the first couple threads in. If you can't might look for some very slightly longer bolts I did the entire front suspension on my 1g and those two bolts probably took the most time even over bolting back up the sub-frame. I didn't do this, But some people oval out the bolt holes a little so that it's easier to start threading in the bolts.
Thanks for the input. So what I guess Im missing is a extra set of hands:) I have pre drilled out the holes but I think I might get some longer bolts also
Pretty much it will go on just not easy... Best bet is a bit longer bolts and an extra hand it's its not held up even you will fight it all day trust me. I didn't do that with the widening the holes because I figured it would have defeated the purpose a bit LOL
