1g AWD cross member bolts
93AWDDSM
883
40
Jan 1, 2009
Vancouver, Washington
can anyone help with actual bolt sizes that I can go pick up at the hardware store?:confused:
I have both part # of the bolts
-MU240024 "10x45, T10"
and
-MU240025 "10X75, T10"
I got that information from this thread
http://www.dsmtuners.com/forums/newbie-forum/364865-suspension-bolt-nut-sizes.html#post152937213
I can get them at JNZ tuning but don't want to wait for shipping and 4 days if I can just pick them up down the road.
EDIT: please move to the appropriate forum - "Handling Tech" Thanks.
They both have a 1.25 thread pitch which is what is going to make them hard to find. They are also both metric 10mm (m10)with the length being 45mm on the one and 75mm on the other.
Soooo... you will want M10 x 1.25mm x 45mm and M10 x 1.25mm x 75mm
You are going to find 10 x 1.5 easier to find, as those are ISO bolts. Mitsus use JIS thread types, and that is typically the 10x 1.25 he mentioned. If you have a good fastener supplier around you may be ok, but not likely to find them at your typical Home Depot or hardware store.
They are also rated as a "10" which you need to get ISO 12.9 to be equivalent. Those are also not typical hardware store variety.
I never had any luck finding metric bolts at any hardware store. I would order on line or is if your parts store can order them for you.
Ok well I'm going to go ahead and order those bolts. for the mean time can I just unbolt the cross member by the passenger side and DailyDrive instead of having it hang by two front bolts?
