1g auto trans, and manual trans turbo's...
gsxferko
143
Jan 9, 2010
Hazleton, Pennsylvania
i know a 14B comes ona turbo 4g63 with a manual trans... what comes in the automatic trans??? whats the difference?
13g turbo's come on the 1g automatics. It is smaller and flows less air. The oil feed, and coolant lines are smaller and the banjo bolts are smaller than the ones on the 14b. Since the 13g is smaller it will have a faster spool but, it will fall short in the upper rpms.
well i just bought a 14b to replace my 13b... do i need anything else to install it?...
It's a 13g, Not a 13B, On the auto 1g cars, And they have 390CC stock injectors.
1g 5spd cars have a 14B, With 450CC stock injectors.
Get a 2g manifold while you are at it. The auto 1g exhaust manifolds are even smaller are more restrictive then the stock manual 1g manifolds. The 2g manifold is a very cheap upgrade. You can get one for $50-$100 used. I have them 8 of them in mint condition if you need one stop by my garage. I also have stock 450cc injectors aswell as anything else you'd need.
i know all that, ive already purchased a 2g manifold... i meant to write 13g... however i do need the injectors, i just need to know if i need anything such as oil or coolant lines to install the 14b turbo
You will need the 14b/16g oil feed line (the 13g oil drain line will fit), both 14b/16g coolant lines, and all the properly sized 14b/16g banjo bolts and copper washers to fit those lines.
I wasent talking to you.ROFL
As for what else you need, tunethis listed that stuff.
Glad to see you are sticking with the car though. Once it's running, I think you'll slowly get addicted :applause::shhh::|
