1g and 2g injectors the same?
4LessThanYou said:
thats a big NO, the 2g injectors are black tops and they have a narrower spray.
You joined yesterday, don't drive a DSM, and have 27 posts, all of which I've seen have wrong information in them. I've had a set of 2G injectors in my car as well as a set of 1G injectors. The car ran fine both ways. Hell the set of 550's in my car now came out of my friends 94. So, you're car should be fine with the mixed injectors in it. You may run into problems with the fuel rail fitting since I believe the 1G injectors are a little longer on the barrel. :thumb:
4LessThanYou said:
im not sure cause i dont know how the ecu would respond to it.
How is the ECU going to even know you changed the injectors? That's the whols reason you can't throw 1000cc injectors into a car and have it run without tricking the ECU. The ECU doesn't know the difference between 450's and 1200's. It will trigger the larger injectors the same way as the stock ones.
4LessThanYou said:
i would also like to know how earth was created and why males have nipples. this is a different account name, i joined this site last year to add to your superknowledge database. and dont tell me all my posts are wrong because thats very incorrect. theres a few that are innaccurate and a few that yes, are completely wrong. but not all. get back to me when u can answer my questions which i would assume that u can answer pretty quick
Check your PM's buddy. :thumb:
Mike1992 said:
Are you sure theyre 450cc also? Will I have to space them a tad off the rail for them to fit? i need definate answers thanks.
1G and 2G stock injectors are both rated aat 450cc's. As far as the 1G inmjectors being physically larger, this is just based on looking at them. The 1G barrel appears to be longer than the 2G one. They both fit into the head and the fuel rail exactly the same way. When changing them make sure you don't lose the insulators that fit into the head and that the O rings on top of the injector are in good shape or you will have leaks. :thumb:
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
