1g aftermarket intake
If you are just getting an aftermarket intake pipe than there is nothing extra that you have to do, assuming that it has a recirc tube. Just remove the old one, disconnect the maf from it, install the maf on the new one and install it.
Yeah you can order one with all the hook ups for all your lines or you can just get the bov return line and order a oil catch can so you dont get that oil in your new air intake but its up to you both will work fine.
I would just stick with the stocker pipe with an after market filter. best thing you can do is wait till you get a evo maf or 2g maf or speed density, tune, and injectors.
"hybrid engine" ? but your askin about a air filter pipe? if you intend on stayin stock untill you do the hybrid engine build/swap than why even mess with the air filter pipe at all? you'll see no gain unless you got a bunch of other crap to go along with it. i dont know? just thinkin out loud i guess
