rarest_90_DsM
- 285
- 3
- Jul 21, 2004
akron,
Ohio
Where are you all at? I see people on here all the time that have turbo charged there non turbo 1g as i have done. Yet we don't have a thread to discuss our trials and tribulation, what setups work how your tuning, what boost what timing? I know we like to think we do stuff the same as the turbo guys, but sometimes i run into weird stuff that is only a problem on a car that was turbocharged after the fact! so lets hear what setups have worked for you and how much boost you run on a n/a bottom end.
my set up
6bolt non turbo block rods and pistons
90 turbo oil filter housing with external oil cooler
1g n/a head ported polished
cams out of a non turbo manual
wally 255 6an line from tank to a trick flow fuel filter
holly fuel rail rc 550 injectors Aeromotive fpr 40 psi fuel pressure
2g mas, Dejon intake pipe
14b turbo ported ALOT!
3in o2 housing with external dump
2.5 turbo back<--needs redone
1g n/a throttle body ported with fiave removed
fluideyne radiator fal slim fan
custom upper intercooler piping
1g bov crushed
act 2100, turbo trans 5sp fwd
90 turbo ecu repined and knock sensor added.
aem uego palm logger
interior gutted
battery relocated to trunk
mild wire tuck.
10psi right now has seen 18psi when i had my super afc
probably some stuff i forgot.
will be doing water alky injection before the end of the summer and getting something to tune with again
if this thread works out ill post some pictures
my set up
1g bov crushed
interior gutted
mild wire tuck.
. yes i used the turbo oil pan but i think im gonna go back to a non turbo pan and weld in a 8an fitting. "for the life of me cant get the return on the oil pan to seal" turns out i did forget some stuff i have a jays alt relocation, coil on plug set up.
