1g/2g awd swap
jimmy's95'
Jun 21, 2006
Johnson City, New York
i bought a 2g fwd turbo with a bad motor and i have a 1g awd witch good everything that some1 smashed the windows out of.....i need to know if anyone has ever put a 1g powerplant awd setup in a 2g fwd before and how to go about doing it....thanks for your time.
-Jim
There are differences. It can be done. Somewhere in these forums and perhaps on VFAQ.com could be the answer. I learned that there are subtle differences all the way around. Even the timing belt covers are different. The 2g is a 7 bolt setup and the 1g prior to may 92 is 6 bolt. The heads will be different to a point etc.
I know it's a common swap and if you do your research, you will come out with the answers you seek.
Vague, but it's my best answer.
i know the engine swap is possible, i've done 3 7-bolt to 6-bolt swaps. i realize the 2g is wider, but i was going to have custom axle's made to be the right lengths and theres a guy who runs a welding shop out of our garage and he used to be co-owner of punishment racing. i know people with 2g's have put 1g rear ends in in them before but seeing the car is a front wheel drive i was just wondering if anyone could give me an idea of how to go about it....
