Cme
- 5
- Jul 31, 2021
Moss Point,
Mississippi
Good evening! I had a Mod 40 TPS Switch A Circuit High P0123 code, so I'm going to order a new sensor. May I please ask if I have to adjust it when I put it on, or does it come ready to plug and play? I did a search online and that's how I found out that there is such a thing of having an adjustment. I came on here and did a search to see if I will have to do I to mine when I get the new one, but no posts came up. If I do have to adjust it, would someone please help a girl out and post a how to link and a video link, if possible, because I have no idea how to do that without messing something up. I took my TPS off by mistake when I was trying to replace my broken map sensor, and just screwed I back on when I realized my mistake, but I didn't know I might have needed to be adjusted so I just screwed it back on and poked the clip thing back onto it. Someone told me to clean my map sensor with wd40, and I sprayed that onto my TPS before screwing it back on because I thought it was the map sensor.
Today, I unhooked the clip and sprayed the pins spot with sensor spray cleaner because I was told that may fix it, but it didn't. Please help me, if anyone will with info and links on how to put I on correctly and adjust it. If it has to be adjusted, would you try adjusting it in case that's the problem in case the sensor may still be good before ordering a new one please? Thank everyone in advance for reading my post. I'll always be grateful for this site and all of y'all. Attaching a pic of the type that is on my car, and that I'll be buying a new one of to try to fix this issue.
I do have a bit of good news to be happy about! I replaced the bad MAP sensor by myself and the code for that problem went away.
Now if I can replace the possible bad throttle position sensor correctly, maybe another code won't pop up and cause me to have to replace something else!
I love this car, but it's giving me more gray hairs with each new issue that shows up once I get each problem that pops up fixed
Hugs, y'all!
