1995 RS Stalling!! HELP PLS!
f_399
Jan 8, 2005
Fort Worth, Texas
Changed fuel filter, air filter, spark plugs, changed oil....
whats wrong?
when the car is not moving it stalls sometimes and it seems like car stalls while running, all of a sudden the car jerks then a light flashes really quick then disappears.
what could be the problem, i need help pls!
dont know if you forgot to say this, but did you put new spark plug wires on there too? Also, did you check your timing, make sure your plugs are getting spark. Is it running rough?
there are no check engine lights on.
should i go have the computer read in autozone... you think it will be able to tell me whats wrong like a misfire?
