Resolved 1995 Eclipse RS fuel pump drive connector and unknown connector
shelbygoat57
3
Dec 10, 2024
Seale, Alabama
1995 Eclipse RS automatic 2.0L non turbo.
I am trying to find the fuel pump drive connector in the engine bay and no idea where it is or if I even have one.
I just put in a new gas tank and everything that goes along with it and I am getting no power to the pump.
Separate, but possibly not, i found this connector behind the battery, just under the brake fluid container. Any idea what it might be?
Thank you.
Based on the diagrams in this post:
2GNT 1995 RS, GS, ESI, 420a MFI Wiring Diagram
Doesn’t look like it has a fuel pump check connector. It does look like if you remove the fuel pump relay and momentarily apply battery voltage to pin 2, that should run the pump.
Any other information you can share for the mystery connector behind the brake fluid reservoir? Looks like it is a 2-pin? What are the wire colors?
