1994 talon tsi build
seyzar18
57
May 1, 2012
ankeny, Iowa
So i finally got my motor sent out to get cleaned and pressure checked and heres my list of bottom end parts that im ordering. :hellyeah:
6 bolt DSM H beam ARP 625 Manley 14021R6-4 **700 HP rod** 1 538.87 538.87
6 bolt DSM I beam ARP 2000 Manley 14413-4 **700 plus, will
6 bolt DSM 85.5 mm bore, 2.0l - 9:1 Manley
Mitsubishi 4, 4G63/4G63T, up to 1992 Race Series ACL
4B1146H-STD,1st Gen DSM Standard Size High Performance Rod
Bearing Set
Mitsubishi 4, 4G63/4G63T, up to 92 Race Series ACL
5M1144H-STD,6 Bolt 1st Gen DSM Standard Size High
Performance Main Bearing Set
Eagle 2034655900A6- 4G63 Crankshaft For 6-Bolt, 88mm
6 bolt DSM oil pump TOP OPMI6
1G DSM complete gasket kit TOP CGSMI6
MIT 4G63/T 85.5MM .051"MLS Cometic C4233-051
Mitsubishi 4G63 M12 head stud kit ARP
Mitsubishi 2.0 4-cylinder 12pt main stud kit ARP
Gates T167RB1-Gates 03-06 Evo / 95-98 Eclipse Turbo / 90-94
Eclipse / 89-92 Galant DOHC / 90-94 Laser / 90-94 Talon / 95-98
Talon Turbo Racing Performance Timing Belt ONLY
Thats just the bottom end, Im looking to get atleast 700whp still deciding on what kind of turbo i want to add to this but thats down the road,
The transmission just got shipped out on Tuesday to Shep trans to get their stage 3 upgrade with a welded diff. that will hopefully be done and on its way back in 2 weeks. The head now has a 5 angle valve job with ported and polished intake and exhaust sides.
How do I post pictures? Also just curious should I go with 8:5:1 or 9:1 compression?
if you pics are too big to post on here using the site upload tool, then upload them to photobucket and copy and paste the link to each pic in your reply. Been awhile since we got an update, you still have the project?
If your looking or 700whp then go 9 :1. An I went with a fp 3582 on e85 272 cams on e85 and reached 700
