1993 Eagle talon Timing problem please help
mkalters
Oct 7, 2004
cranbetrry twp, Pennsylvania
I changed my timing belt and now the car backfires like crazy and will not start. I brought up the number 1 cylinder to top dead center and aligned the cam markings together. What am I doing wrong please help.
CAS 180* out.
Did you time the oil pump also?
There's more than just the cam's that need to be aligned.
Did you follow the VFAQ exactly?
When you say #1 is at TDC, are the camshaft alignment dowels at 12 O'Clock?
