1G 1992 tsi ignition control problems
AdroitPostal
39
16
Apr 13, 2022
Grande Prairie, AB, Canada
I recently just installed a new ICM in my 1992 eagle talon tsi. Was able to get it up and driving, and I shut it off, and power was instantly low again. I tried boosting it, it tried and failed to crank a couple times and now I can’t get any power through the car, even by boosting it. And I now cannot crank either. Where did I go wrong and how do I fix it?
We don't use the term ICM so I'm not sure exactly what it is you changed. Was it the Engine Control Unit (ECU), the Power Transistor Unit (PTU) that charges the coils, or something else.
You talk about power, I assume you mean voltage from the battery. If so have you measured it and have you charged it up?
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
