1990 tb seal question
tsd123
135
Aug 9, 2006
Hickory, North Carolina
I am trying to find out where i can get tb seals for my 1990 talon. I found a thread that listed SKF seals having the correct sizes. The part numbers listed were #3030, and #3930. Could someone please verify this.
Here is the site. I went under Seals North America part lookup.
SKF Seals
Because your car is a '90 you have one side that uses a smaller shaft seal than the other side, unlike the '91-'99 throttle bodies that have shaft seals that are the same size.
You'll need these (2) sizes when you order new shaft seals...
Hope that gets you what you need.
:dsm:
I just changed out the seals on my 90 throttlebody. You need both 3030 and 3930. The TPS side is the smaller seal. Don't forget how to put the TPS side back together. There is a washer, nylon washer and an E-clip.
So I did as BLT on the 90 gsx and found the tb seals were horrible. I found the same info lised in this thread but, having issues finding a supplier info on thier site or a way to order. Any help? Also once the order was placed how long did it take to get? Thanks
