1G 1990 talon problems help please
Jayy
Jul 15, 2015
Phoenix, Arizona
I just bought a 1990 talon TSI this car has been. A headache since I bought but I love it and want to turn it into a beast but I'm still learning and going to school but this morning I drove my wife to work again and the road was open so I got on it a little in third gear it picked up as it should I left off around 5000-5500rpm and I saw a red light pop up wasn't sure what light it was at first and it came back on and would go away it was my check engine light when the light would come on the car would die it would not accelerate the Rpms dropped down to 1500 until the cel went away and it would pull hard again. So when I got around the corner from my house I got it on again and it was fine but not full boost. It felt like something stuck for a second and went away it was 50degrees outside but the engine was warmed up
A little background about the car the previous owner rebuilt the engine and tranny less than 1000mils on the build, it was just a stock rebuild the only thing the has done to it is a 16g turbo, and a 3in exhaust(which is disconnected from the down pipe back because the past owner bent the exhaust and it hits my driveshaft while I drive was planning on taking it to a shop haven't had time yet) but it still has stock side mount and could have bigger injectors I'm unsure though stock ecu
Give the ecu a good look over. A visual inspection is all I would do at this point. I struggled to figure out issues with mine, after checking out the board on the ecu, it was apparent that the ecu was the issue. One of the caps had leaked. Keep in mind the car is now 25 years old.
Did u buy that off Craigslist in Phoenix? I remember seeing that talon. I would go through the basic stuff first dude.
Boost leak test, check the ECU board, double check all your grounds. What kinda paperwork did the guy give you any receipts?
There's a way to check what the CEL is saying, there's some articles on how to do with a voltmeter or light bulb or audible tester. And what happened to the turbo?
