190 or 255??
GORBS88
549
3
May 26, 2004
Oliver, BC, Canada
okay, just a quick one....how much power will a 190 flow up to???? i am not goin to go to serious.....domt really want to go more then 300hp at the crank.....i have heard the 190 will out fuel a big 16g...??? is that true......the biggest i would ever go is a small 16g.....will the 190 be enough???? pls help....
Yes... a 190lph Fuel pump its good for even a B16g... but not recomended for a bigger turbo...
But if you're getting it just to be on the safe side while adding a few more lbs of boost it is indeed a good choice.
I learned the hard way. I bought 550's and a 190 pump for my 14B. I said I'd never go bigger than a 16g. I'll be buying my 50 trim at the end of next month, along with new injectors, pump, and regulator. :p
All I'm saying, is that you may be better off just getting bigger to begin with. I should have.
98eclipseRS said:
I 190lph will be more than enough for the majority of the member of this site.
Hit the nail on the head.
16g.....no problems
Many people run there 20G's on them
and I know several that run there 50 trims on them(23-25psi).
I'm runnning my 50 trim on a 190 now at 20psi. No problems so far.
A stroker or anything larger than a 50 trim...upgrade(just my opinion)
