18 vs 16.
adamism
355
Sep 9, 2003
Sacto, California
I have stock GSX rims right now; they weigh about 25lbs.
If I were to go to Rota Slipstreams 16" that weigh about 13lbs.
Would that make a considerable amount of difference in acceleration?
Really? Someone told me it could improve your 1/4 time by .4 secs.
Anyone else have evidence to back this up?
Seems like a stretch. First 13 x 4 = 52 (not 48). Estimates I've seen of the equivalent of rotating mass to static mass are about 1:2, meaning a pound of rotating mass is like two pounds of static mass. So loosing 52 pounds of wheel weight is like loosing 104 pounds from the chasis.
100 pounds is worth about 8 hp in my power to weight book. I don't think 8 more hp will get you 0.4 seconds.
This is all speculation of course.
I heard the ratio was closer to 1:5 from unsprung to sprung weight. So losing 48 lbs on your rims would equal to 240lbs on the track. That would be quite a difference.
tires have alot to do with rotating mass as well..... dont forget that!
Actually it's closer to 1:1.5. So losing 48 lbs on your rims would equal losing 72 lbs of static weight, which is still a lot.
edit: I misread the original post. Unsprung to sprung is 1:1.
According to Herb Adams, it's 3:1, chassis weight to axle-speed rotating weight.
Charles
If i remember correctly, given a good driver and all, for every 100lbs of chassis wieght lost you can cut .1 sec off you 1/4 times
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
