17x8.5 wheels with 245/40/17, 30 offset will rub???
blkGSTspider
124
Jun 27, 2005
northridge, California
does anyone have same wheel size and the tire size???
there is nothing about 17x8.5 on VFAQ
it ALL depends on the offset...to fit 245's most people get 8" wide with a 40mm-35mm offset but BEWARE since urs are 8.5". you might want to get closer to 40mm. I have 17x8 w/ 35mm offset and they stick out a lil in the front with 225's. It will stick out a good amount if i had a 8.5" width
hm...
lets say i got8.5 wheels with offset 40-35....
does it going to contact with the suspension??
and..
so...its going to stick out and rub???
I would ask Wret about this one, he seems to be most knowledgeble about wheel and tire sizing. I would think going with a 35 mm offset on 8.5" rims would stick out a bit but with 8.5" rims I also think they would rub the suspension if you went any more than 35 mm... Hopefully Wret will chime in and set us all straight.:thumb:
Yes, 245's on +35mm offset will stick out about half an inch and you will have a hard time getting them to tuck. On +40mm offset wheels with moderate lowering and corrected camber it is barely possible to tuck the wheels .
