4gfun
Supporting VIP
- 2,009
- 56
- Dec 10, 2007
Ask Me,
Virginia
I can set base timing to 5 degrees BTDC with the timing connector grounded, but if I unground the connector to leave timing mode it advances to 17 degrees BDTC. I can see this with the timing light or MMCD.
What could be causing this?
Thanks
Just took a look at the RT Tuner Pro map as provided by the previous owner. It is set to 17 degrees at 750 rpm and 18 degrees at 800 rpm.
Thanks
