16G Oil Restrictor Help, Over 100psi Oil Pressure..
How come the oem turbo isn't run through the head then?
Also when I asked how to run through the head, people say it is not possible with the oil feed line you use, if it is that bolt that is in the front of the head near thermostat, it seems bigger then the threads on the oil feed for 16g.
And why don't holset users run through head instead then? They all run through OFH. :confused:
OEM mitsu turbos ARE run from the head. Whoever said the feed line bolt sizes are different is an idiot. I used the SAME oil feed line from my 14b on my 16g. Holset turbos are not MHI turbos.
