16g oil lines and water lines locations
alex09
Jan 18, 2005
Vestal, New York
I know that the oil line goes off the 16g turbo to the oil pan but I was wondering where the second oil line goes, will and where will it tap into, the oil line or is it the oil pump. I am asking this because I am turboin my 420a engine and my buddy told me I need two oil lines. Also hahn offers a feed and return kit that comes with one oil line and a dump tube, is that good and is there cheaper kits other than Hahns which is going for $99.00?. Also since the 16g is a mitsubishi turbo I was wondering where the water lines go, I know one water line goes from the turbo to the water pump but where does the second water line come from and go to? Please help me or email me at [email protected]ks
selmerguy said:
i dont think you need them either. however our motors like to run hot so the cooler the better.
As long as you have proper oil cooling your fine without water. Just make sure to allow the turbo sufficient cooling time after heavy use.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
