16g is on but boost controller isnt working..
xucpxeclipsex
69
Oct 24, 2005
Santa Maria, California
well here it is.. i put on the 16g today.. and i floored it in first and then second and hit 22 psi.. so i try and lower the boost all the way to stock.. and it still hits like 20.. so i go the opposite way and it hits 20 again.. idk what it is.. my boost controller worked fine before.. any advice??
Look Up Porting your 16-G for boost creep and do a complete boost leak test. I am having the same issues you are and am finding boost leaks all over the place because this turbo is putting out more pressure than my system has ever had.
There'a few things to check:
1. Boost leak test to 25psi (as Travis already mentioned)
2. Make sure the MBC is correctly hooked up
3. Did you tee off of the BOV line or the J-pipe? (J-pipe makes the BOV react faster)
4. Make sure the wastegate arm isn't hanging up and not allowing the flapper to open
A Small or Big 16G doesn't have creep issues like the EVO III. Please update your profile and let us know which 16G you have.
Have a look at all of those and then get back to us.
Andy
I'm with andy. I have a friend that installed his mbc backward and it hit really high boost. If I remember right he had the Turbo-XS MBC with the course adjustment screw and the instructions were actually back words.
Same probelm here. Hooked it up to how the insturctions from the seller. Thought about it and relized they were idiots (LOL). I was pushing constant boost all the way up to 27 PSI. Be careful :thumb:
