150 amp alternator
las_vegaslazer
234
Oct 10, 2004
omaha, Nebraska
I wanna see how long it puts out. I need a better alternator mines from kragen which suck and goes out every few months
This place SUCKS!!!! I ordered one and the bearings were bad. Sent it back and got another. This time the voltage regulator is bad. I tried to contact for a refund and he told me I was SOL and that he would offer a 50 core refund for a return. He said I was breaking the post or something. I know he was BSing. I put the stock one back in and its fine. It doesnt take a rocket scientist to install an alternator.
Save yourself a migraine and just send it back and dont use this company. Their products and customer service are garbage!
Excessive Amperage - High output alternators by C.S.A.
Ordered a 200amp from there, comes with 3 year warranty. Great service and they can even color the stator
Direct Drop in, no wiring involved just have to upgrade your positive cables like any other high amp alternator would require. I also recommend re-doing your grounds.
There is no modification to the connector or fuse box necessary.
I have used Powermaster Alternators in the past with no problems. They work awesome and are usually underrated.
just got the alternator yesterday and it looks good. Track opens april 4th so I will install before then. I will let all of you know how well it works.
Installed alternator today and all went well! Bolted right in. Start up was 14 volts at idle. With both pumps,fan and all lights it droped but went right back to 14volts.
Need to do an oil change and change to plugs. Then we can lean on it and see what we have at 9500 rpm. I am still going to the track this saturday(1/8 mile:notgood:) and will let you all know how the alternator holds up.
Did you upgrade the wire? I plan on doing that with my Galant when I change my alternator out.
