14b w/ 16g wheel
trbotaln
633
9
Sep 7, 2004
hidden hills, California
will a small 16g wheel fit in a 14b compressor housing? And will a 16g turbine fit in a 14b exhaust housing? would their be any benifits if they fit?
wow,
thanx for the info. Can I stick a 16g turbine in the exhaust housing or not?
Tallen said:
Yup....as long as it is a regular old 16G.
Yep because they're the same wheel sm/lg 16G ;)
http://www.vfaq.com/mods/Turbo-compare.html
Just my .02.. if you're planning to build a 16G from a 14B and new parts.. would likely be cheeper to just buy a used 16G as the low cost of new and the sheer# of used ones around has depressed the market value of used turbos.
When rebuilding it's a good idea to get the assembly balanced to ensure logevity :thumb:
