14b turbo
winterftbl
318
Sep 7, 2005
santa ana, California
I installed a 14b turbo in my 2g and fixed all the leaks but now the coolant is disappearing. I mean i fill it up and in a matter of minutes there is no more fluid. And its not leaking anywhere under the car and under the turbo is dry. Does anyone know where it might be going?
where is the heater box located in the interior because the floors are not wet. And how would air buubles affect the level? I fill it up to max and it drains all the way to nothing. So I do not believe its just filling up.
air bubbles will take up space in the cooling system, which means when the air is released the space the air was taking up, will now be replaced by coolant.
99% of the time when you drain your cooling system, you have to bleed it of air, sadly dsms dont have bleed screw on top of the thermostat housing to do this easily. so its up to each person to figure out how to do it there own way (most gm cars have a bleed screw, makes like easy)
The heater box is behind the dash, look at a service manual. Check your oil for coolant contamination. Are you seeing any smoke from the exhaust?
no, there is no smoke coming out of the exhaust, and as for the coolant it has not mixed with the oil because that was one of the first things i checked. But i will check again.
