hellotbone
- 1,032
- 22
- Apr 15, 2003
Well I installed my ebay 50 dollar 14b for 25 bucks last night took me 4 hours and its on nice setup. Reused everything from my car other then oil feed line 14b caem with one so I went off the head.
My car absolutely hauls with it the motor is like it wants to pull to redline now and its accellerating so much harder there its unreal I used to be able to watch my timing with the stock turbo in first gear cowly climb to 20* now it pulls 1st so quick its hard to read the numbers on the pda I gotta logg it to see it
My question though is lag or spool up are they slower because mine is laggy could be the crappy AUTO trans though. If I mash is about 3/4 through an intersection is nails 17psi and holds it till redline with MBC of course.
If you roll into it though it takes a long time to spool and I just wanted to know if that was normal its about 2x slower spool then my stocker.
I also found my stocker cartridge was split and leaking oil! Good thing I dediced to swap!
I also ported the 14b removed the ridge or step opened the flapper hole and cleaned up the WG dump and then removed the step in the o2 housing but didn't go crazy there how much do you cut? I ported the hell outta the 14b housing on the intake side but not the exhaust so much. Anyways my car does rip now and anyone that says the swap isn't worth 25 bucks and 4 hours is nuts!
!My question though is lag or spool up are they slower because mine is laggy could be the crappy AUTO trans though. If I mash is about 3/4 through an intersection is nails 17psi and holds it till redline with MBC of course.
