13b turbo to a t25? please help
95tale
110
Jul 26, 2013
hamersville, Ohio
Ok here is the deal. I have a 93 eclipse gs non turbo that had a t25 turbo on it that the last owner put on. I just got my new turbo engine to put in and it came with a 13b turbo from an auto eclipse. So my question is. Can I put the t25 turbo back on Cause my fmic that is on the car wont work for the 13b turbo I would need to reroute the whole thing and buy new piping and i dont have the money or time to do that. I kno its not a common thing to do but I need it done. Thanks
The turbo you are probably referring to is the 13G Turbo which came with the auto 1st generation dsms's. Swapping it back to the T-25 shouldn't be too difficult. Swap the 1G exhaust manifold for you 2G one, built the turbo up, and the only modification you'll probably need to make is probably just for the coolant lines for the turbo.
I thought the 1g and 2g manifolds were the same. And would I just need new coolant lines or reroute them?
The 13g has a smaller exhaust inlet than a T25. All you need is a 2g manifold, oil return tube for a T25, and oil and coolant lines. I do not believe that the 13g oil and coolant lines will fit the T25. You can get the parts used for cheap. You can start with the classifieds on the this website for sourced parts :thumb:
Ok cool thanks
Ok my connectors on my engine harness are brittle and breaking do I need a new harness or can I wire them back up
  • Wanted 6 bolt NT water pipe
    • chrisman287
