11 dollar boost leak tester
spawn87
908
3
Dec 6, 2007
sacramento, California
It seems like most boostleak testers are to expensive so i made my own and created this as a write up of how you can to for about 11.00:thumb:
PICTURE ONE: you will see the parts needed
.gas leak tester
.3/4 doble female ended joint
.2'' PVC END
.Teflon tape
.pipe glue (or other that you feel is strong enough to seal air tight)
PICTURE TWO: I bought a cap that had lines on it because the lip at the bottom is exelent for making sure the coupler dont slip of. (at hight psi it can hurt you bad)
i sanded the vertical lines of so it would be nice and round.
PICTURE THREE: drill a hole on top of cap to match the 3/4 joint (make it slightly smaller for good grip.
PICTURE FOUR: put glue on both the one female end of joint and cap and screw it in. DO NOT PUT GLUE ON OTHER END.
PICTURE FIVE: after it dries a little bit flip and add more glue on the inside. i like to flood it a little to make stronger bond and to ensure air tight seal.
PICTURE SIX: WHEN DRIED, put teflon tape on other end of female joint and screw on the gas tester. YOUR DONE!!!
PICTURE SIX: pictures dont lie :thumb::thumb:
hope it helps some of my fellow broke DSMERS out there LOL
  • Wanted 6 bolt NT water pipe
    • chrisman287
