spawn87
- 908
- 3
- Dec 6, 2007
sacramento,
California
It seems like most boost leak testers are to expensive so i made my own and created this as a write up of how you can to for about 11.00
PICTURE ONE: you will see the parts needed
.gas leak tester
.3/4 double female ended joint (the length is up to you. i used 1 1/2")
.2'' PVC END
.Teflon tape
.pipe glue (or other that you feel is strong enough to seal air tight)
PICTURE TWO: I bought a cap that had lines on it because the lip at the bottom is excellent for making sure the coupler don't slip of. (at high psi it can hurt you bad)
i sanded the vertical lines of so it would be nice and round.
PICTURE THREE: drill a hole on top of cap to match the 3/4 joint (make it slightly smaller for good grip.
PICTURE FOUR: put glue on both the one female end of joint and cap and screw it in. DO NOT PUT GLUE ON OTHER END.
PICTURE FIVE: after it dries a little bit flip and add more glue on the inside. i like to flood it a little to make stronger bond and to ensure air tight seal.
PICTURE SIX: WHEN DRIED, put Teflon tape on other end of female joint and screw on the gas tester. YOUR DONE!!!
I AM NOT HELD RESPONSIBLE FOR INJURY OR ANY ACCIDENTS YOU MAY HAVE FOR MISUSE OR DEFECTIVE PARTS.
hope it helps some of my fellow broke DSMERS out there
.gas leak tester
.2'' PVC END
.Teflon tape
