10 second turbo?
bOOstd GSX
931
Nov 29, 2003
Plum, Pennsylvania
If I were building an engine to run 10 second passes all day long, what turbo would I go with?
depending on supporting mods.......garret 60-1....but it will only get u there with everything to help it.
if you are running 10 seconds the rest of the car would be more important than the turbo.
lots of different turbos could get you there... COULD... its all about supporting mods. i would say that and proper tuning are much more integral factors....
If i were looking for a 10 second car. it would use a FP3565 built motor and i would then spray the living piss out of it.
Say these mods: :D
Modified Stroker block (6 bolt crank platform)
Fully Cryoed block, crank, rods, and pistons
GReddy big front mount
GReddy Plumbing
GRedyy Type S
990cc's
Weldon racing pumps
AEM EMS
Custom Wiseco Pistons (8.5:1 ratio/.020 overbore)
Eagle Rods
ARP main studs
All new freeze plugs
Balance shafts removed
Butcher crank
New oil pump front cover
New oil drive gears
Line hone, torque plate boring, decking, and plateau honing of block
Assembly of shortblock
Balancing and blueprinting of rotating assembly
File fit rings
All new bearings
1G reconned oil pan
Cryoed Level 3.5 head (1mm oversized valves)
New “big hole” lifters
Head “wings”
Crower spring kit (titanium retainers/springs)
HKS 264/272 Cams
New cam seals
Cometic head gasket
Fidanza adjustable cam gears
1G Coil Pack
Powercoated rocker cover (your color of choice)
1G T-Stat Housing and outlet
’90 CAS
1G Water Pipe (refurbbed)
Lower Radiator Hose
Magnecore Wires (1G)
1G Water Pump
New Timing Belt Cover
Timing Belt Undercovers
Magnus Sheet Metal Intake
Fidanza Aluminum Flywheel (6 bolt AWD)
Stainless steel rocker cover and oil pan bolts
1G timing belt kit
Modded motor mount (timing belt side)
...all of this on a 6bolt in a 2G GSX.
just maybe these mods, not to say I have these or anything.:|
That's a hell of a wish list.
To run 10's reliably, you need to be able to support a little over 500 whp. That means a turbo that can flow around 60 lb/min, which gives you a couple options. GT35R, GT-14, FP RED.....
well this is my "wish" list, that engine can support 650+ hp with reliability... so whats the suggestion on the turbo?
just get a full t4 with 62-1 or a full on gt40, unless u plan on driving on the street, below 4k rpms, with boost. are you planning on a track only car or a street driven sort of thing?
well it wont be daily driven, but ill take it out every once and a while, maybe saturday nights and stuff.
I would go with 272's for both your intake and exhaust cams. And go with a front mount with short route piping.
Wow guy, didn't you READ the rules about posting turbo-related questions? 11,500 members already did.
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=12447
Besides the fact that KPT4321 answered you with an excellent response, and then you blatently dis-regarded his answer with a:
bOOstd GSX:
"well this is my "wish" list, that engine can support 650+ hp with reliability... so whats the suggestion on the turbo?"
:rolleyes:
Yes, on a "Bench-racer" dyno, your setup would run 10's on pump gas, at rediculous AWHP levels, trashing your stock tranny in the blinkity-blink of your eye.
Get real, dreamer...
:dsm:
if done right the turbo can get you in the 9s w/o spray.... thats my goals with it :)
KPT4321, I didn't mean to say "whats" i meant to say "thats". Sorry for the confusion.
Secondly shepracing is building the tranny full race spec.
Thirdly, you shouldn't try to put something down in which you know absolutley nothing about.
Finally, if you have any suggestions or questions on the engine, turbo, other parts for the engine, either PM me or post. All the help is gladly appreciated.
No turbo in the world will net you tens without the rest of the car to go with it.
Shepherd bought a buscher car that was running 10's on a 20G OMG , how many people can say that? Its POSSIBLE, but unlikely. It CAN, but it probably wont. See what Im saying? Its all in the setup. Nobody is mentioning weight reduction. A lot of weight loss is needed to hit those 10s. And yeah, tuning is huge also...
Better have a big wallet...
Did I hear some cry out for sponsors????:confused:
If so then let me know cause im in need of some serious hay too:laugh:
Who said money cant buy you happines ?? well maybe it cant ,,but it can shure buy you a ten sec street car .
hey i am goning to run 10's on my stock motor and 14b.
i'm at 14's right now ........maybe yes maybe if i Shift faster ......yes that will do just shift faster....
:D :D :D
yes i am joking
