1.8 non-turbo chip???
speedy_talon28
364
3
Apr 1, 2006
elkhart, Indiana
The only chips that I have seen are for 2.0 dohc turbo engines but, I can't find 1.8 sohc non-turbo chip. I know they exsist because I have a 1.8 eprom ecu (159561E) Does dsmchips.com have them or where could I find one???
i didnt know some 1.8's had the eprom.the only reason the turbo eprom guys upgrade is because of bigger injectors,rev control,and so on.a chip probably wouldnt benefit you,since you have 92 hp like ramenpride said.youd be better of getting exhaust and intake upgrades more than a chip.
well, as I hear from other fellom dsmers, they're not that big. but, I wonder why there are 1.8 eprom ecu's if the chips aren't in demand or that big????
yes,but what different instructions would you actually give it? Are you gonna raise the rev limiter?install bigger injectors? Or are you just looking to fine tune your car? If so an safc might just do the trick. You might be able to squeeze 8-10 more hp with one. Or more,who knows. Not much of a market for the 4g37. If anything,write dsmchips and see if they can do abything for you.Good luck.
speedy_talon28 said:
I thought they were made to give the ecu different instructions to work with.
My point is that the factory didn't make then so you could change the oode, They made them so they could ship cars without paying an arm and a leg for a custom CPU if they were making small numbers or so they could ship cars while they waited for the custom CPU with the code burned into it. An EPROM ECU costs them a couple of $ more each and over a couple of million cars that is real money so they don't want to do it unless they have to to make more money.
Nowdays it's cheaper to build ECUs that are programmable with flash and such but not 10-15 years ago.
It you really want a custom chip and are willing to pay for a one off, there are people who can do it. But I can think of better things to spend the money on.
Steve
Sorry, I forgot to thank everyone for their help :thumb: I decided to not get chip for it so, I basically wasted my money on that eprom ecu. :sosad:
It looks basically like this turbo ecu minus a thing or 2
I also bought a chip for it for only $35.00 from a company off ebay
That's a turbo EPROM ECU board from a 91-92 AWD MD166262.
The non-EPROM versions of the 1.8L ECU are sigificantly different than the non-EPROM 4G63 ECUs and that's why I wanted to know what it looked like, plus to make sure what you have was a 1.8L EPROM ECU.
Steve
I know but I don't a digital camera so, I can't take a picture of my eprom ecu, I made sure it was for a 1.8 non-turbo and it is the correct one (MD159561)
