04 Evo Turbo Manifold
MountainDew
494
3
Jul 7, 2007
Manhattan, Kansas
Maybe I just suck at searching but I didn't find much information on this.. I have another question as well anyways.
There's a local guy selling a stock 04 Evo Manifold and 02 housing for $50. I asked if he'd just sell the manifold and he said he would for $30. This will bolt right on right? I mean it will go on the stock T-25 just fine? I need a new manifold mine cracked 3 times when I took it off and I know the Evo ones are stronger and flow quite a bit better. I figure for the price it would be worth it.
But onto my next question.. would the 02 housing directly bolt on and would it be worth the extra ~$20 or so?
All of this will be going on a 95' Talon. Any input/help is appreciated, and my apologies if it's been discussed over and over. Thanks :talon:
It may fit on your head, but i doubt if your turbo will bolt up. The O2 housing will not fit either.
What if he gets the stock turbo, or a replacement turbo that uses the stock pattern? He should be able to use it then, right?
Anyways, my vote is to get a stock 2g manifold, or an Evo3 manifold, or one of the other cast stock mani's.
The EVO motor is flipped compares to a DSM, there is no way you can hang a DSM turbo on that manifold and expect to clear alternator, PS, water pump...etc.
