02-03 old school fp green Oil feed and return fitting
95Dsm22
80
Nov 3, 2015
La Puente, California
I need help finding what oil feed and return fitting I need for this . Some people say I can use the one from a 16g but wanted to confirm before I buy it . Any help is appreciated.
Assuming the inlet thread is 12mm x 1.25, any feed fitting from a 16G will work. You should be feeding this turbo from the filter housing using a restrictor of an appropriate size to get the pressure at the inlet to around 50psi or so.
Any TD05H drain hardware will work.
