1991 Eagle Talon TSi AWD
1991 Eagle Talon TSI. Bone stock (everything), 6bolt, 5 speed, 3bolt LSD rear.
Today's goal is to finish this control arm up, 1 more full coat of black and I'll be happy
Next I'll begin cleaning up the spindle/knuckle whatever floats the boat while that dries
AND if I'm lucky enough I'll get the sway bar cleaned up and prepped for paint.
All cleaned, prepped for paint💪 2 coats of primer, I didn't lay any black yet just wanted to get some paint on these
I think for just primer they look alright, I'll be happier when they're finished and back on the car😉
I even managed to get the sway bar all cleaned up and 2 coats of primer thrown on given I was limited on time tonight.
Same primer gray, although the sway bar will be finished in a "coastal gray" I found.
Woohoo! Pass. Control arm is done! I forgot the bearing for the hub/spindle so that'll be something to do over the week.
current state of my interior 🙃, have a tight spot in the shifter I need to figure out(almost like a small bind) still need to get this headliner done and the interior can go back together
Check it out, sway bar is back on (my God that was a PIA). I read a few older threads on here that said it would be one of the hardest things to do and I will say it was horrible, BUT it's on and it looks good. I think at this point I need to order more parts🫣, and put the pass. side back together.
I have a RockAuto cart put together to finish up the front end(all the rubber brake lines, 2 struts, sway bar end links, calipers and rotors), except for the brake hard lines. I will be doing the OEM 2 piston "big brake" upgrade from the 93+ DSM or 91/92+ non turbo stealth/3000GT. Getting closer!! Have I mentioned how excited I am yet? I'm sure the wife is tired of hearing it by now😂. Once the front is done I'm gonna move this party inside the garage and get the rear subframe out. That's where the fun really begins!
Finished up the pass. side, at this point I need to order parts. I need to get some cash stacked up for this next RockAuto order. I got my center console back together, the shifter is nice and tight once again. Maybe this weekend I'll finally get the headliner done and I can get the interior back together
Ya know for never having done or attempted a headliner before, this was actually way easier than I expected it to be.
I got this fabric from hobby lobby down the road for 12$, the adhesive kinda stung at 30$ a can.
Do you guys like my small collection of sockets😂 probably didn't need to do that but eh if it helped awesome if not oh well.
the underside was a lil goofy looking but you'll never see it again.
final product! It's got a few wrinkles on the edges that I'm annoyed about but again this is the first one I've ever done and I'm more than happy with the end result.
Its hard to get an "in the car" picture, but I finally have the interior back! Woohoo, I plan to get the shop vac out and give this a good deep clean before the seats are put back.
Here's more recent photos of the car as it currently sits. The interior is back together and looks pretty good actually, I managed to get the god awful smell out of it too.
I am just about finished in the front end as far as suspension is concerned, still need small odds/ends. I am going to clean up the calipers, figure I'm replacing the hard and soft brake lines, might as well clean/paint the calipers. I do have all the skirts too, they're in the garage I have some small spots of rust to handle before they go back on.
The hood is popped open, I didn't realize it til after all these photos.
I thought I took more photos but I must've been in the zone 😂
And in the blink of a scroll on my build thread, the engine is out! I had to reorganize everything in the garage to tuck my little 4G in the corner.
I need to finish up the passenger strut, and then I will pull the front calipers and soft lines to replace/refurbish
Well I made the drive for a unit I never thought I'd get my hands on. A full 2G auto swap from Rix racing, I won't be using all the parts I got so I will have some listed for sale once I find out what I need for sure.
i'm excited, as this is some end goal stuff with this car, granted we're still YEARS from all that but the wheels are rolling.
I got the 5 speed shifter base and cables out, and the Auto base/cables in. If anybody is looking for a 91+ shifter base and or cables I got them😉 hell I even have a spare set of 91+ cables too. I think I'm gonna do some doodling on the white board to get a course of action as there's a lot to still be done to the chassis. Progress is progress
Are you selling the manual transmission? I see your license plates are PA… I’m from PA too. Could always use a spare trans.
I actually already sold the trans, but I do have 2, 22 spline T cases if those would interest you. One has the cast head, the other is aluminum. I do have the casing of the trans I tore down too if that's of interest.
Bam! Engine on the stand. Nothing crazy for this, clean it up and get it all up to date maintenance wise, delete the balance shafts, clean up the oil galleys behind the pump, the usual.
tucked in the garage until I'm ready to tear into it again, anybody need some rear seats? I have 2 sets here😂 gray/black and the grey/rainbow.
No thank you i appreciate it though. What area are you in? I’m close to Pottstown. If you need parts let me know. I have a fair amount of interior and some other stuff laying around.
