ECMlink [Resolved] Knocking, don't know why.
Looks like 13 degrees is just too much timing advance for it on gasoline.
Do you have a boost gauge? BoostEst is going up to 21-22 psi. Is that about right?
You could try it a little richer. The LC1 is saying 10.9 AFR just as you head into the knock areas. Your OpenLoopMaxOct table says more like 9.6 in that area around LoadFactor 2.25 so you are leaner than the table. So you could calculate a new global fuel from a smaller injector size like 900 or 950cc injectors. That would make your global fuel around -50 or -52 or so. Actually instead of doing that, you could just move your sliders on the fuel adjustments table back up to 0. They are at -3.1% now, so they are making it leaner.
  • Wanted 1g Need 1g AC tensioner bracket
    I am in need of 1g AC tensioner bracket - looking for complete with bolts. Recently bought 92...
    • JLavetsky
    • steelcurtaindsm
    • Syclone#334
