1997 Eagle Talon TSi AWD
Parts installed:
-DBB PTE 5857 dsm .63ar
-2.5” o2 housing w/ 38mm external wastegate
-Tial 38mm wastegate
-RTM 3” down pipe w/ cat delete to HKS muffler
-ETS race intercooler 3”
-Tial Q 50mm bov
-Kelford 272/272 cams
-Antilag COP kit Prius Denso coils
-Frontline fab billet valve cover
- Dual Radium catch can 10an
-Speed density (AEM 5 bar)
-Non cruise control throttle cable
-Battery dropped lower (Miata battery)
-Ecmlink v3 full ecu
-AEM AFR/boost gauge
-IPT restall converter
-Forced Four Smart 100.1 shift box
-Evo X MR paddle shifter
-FIC 1650cc injectors
-Walbro 450 fuel pump w/ stm rewire
-Fuel Lab mini FPR
-6AN feed line
-fuel lab fuel filter (40 SS micron filter e85)
-gm flex fuel sensor
-rebuilt head 3g lifters, kiggly springs, ported oil port
-ARP L19 head studs
-Felpro head gasket
-Fluid damper crank pulley
-Fp exhaust manifold w/ arp bolts
-Evo 3 IM w/ 1g NT TB
Just a little update to the build. Car currently dyno’d 470whp and 370wtq @30 psi on pump e85
-Tial 38mm wastegate 17lb spring
-Tial Q 50mm bov
-Radium dual catch can 10an
-Battery dropped down(Miata battery)
-AEM AFR/boost gauge/trans temp
-Innovate oil pressure gauge
-Stock converter IPT restall
-IPT trans rebuild kit
-welded center diff
-Quaife front lsd
-Kiggly flex plate w/ Kiggly Diamond shim
-ARP Flywheel bolts
-Fluidyne E-line 35 row OGEN.STP.102 trans cooler
-translab shift kit
-Fuel Lab mini FPR -6AN
-6AN feed line
-97-99 split thrust block: Eagle H beam rods, wiseco 9.0:1, stock polished crank, ACL race bearings, kings thrust washer, RSB straight cut oil gears.
-head: oem valves, top line revised lifters, Kiggly street springs, Kiggly HLA
-Evo 9 Kevlar timing belt
-ARP L19 head studs
-SCE Cut Ring Head Gasket
-ARP crank bolt
-SBR short route intercooler
-ABS delete
-Vibrant 10AN turbo drain
-turbo smart turbo oil filter 14” and 12” line
-Megan Racing aluminum radiator. 2 Spal 12” fans one pusher one puller
-PQY 16 row engine oil cooler
-Setrab billet sandwich plate
-ARP Wheel studs
Wiseco 6597M855 85.5 9.0:1 w/ Line2line coating
Ring gap: top 024”/ bottom .028”
Car weighs about 3300lbs with me in it. Left lane. I was finally able to take the car to the drag strip but I could not get the car to get on the converter and build boost. I was only leaving on about 3 psi. Even with a terrible 60’ I’m impressed with the mph. I’m hoping once I get the launch sorted to be somewhere in the mid 10s.
Finally got a good run in! Left lane. Got the car to spool up with a 100 shot of nitrous. Launched at 4000 rpm. The car felt a little flat leaving the line but overall super happy with the new time! The car now has an 8.5 cert cage. It still has full interior, a/c, power steering, and abs. The car is also on 235/60-15 Hoosier’s. Next I’ll be installing a Morrison fab exhaust and an HPT 6266 T3 .63ar. Then get it dialed for the Redwood Rally Drag and Drive in September!
Finally got the Morrison fab exhaust and HPT 6266 T3 .63ar installed on the car. The car still drives very well on the street with this set up, I was very surprised by that. Recently made it to a test and tune where I was able to get some data. The car is currently at 35 psi. I was on a hard tire for this pass. I ran an 11.06 at 134mph @2600ft of elevation. I red lit (-.394) but held it until the left lane took off, then spun off the line and let off about 100 feet early or so. The ecu said I was going 140mph when I let off. Overall I’m super stoked about the pass and can’t wait to go out again in a weeks!
  • Wanted 1g Need 1g AC tensioner bracket
    I am in need of 1g AC tensioner bracket - looking for complete with bolts. Recently bought 92...
    • JLavetsky
    • steelcurtaindsm
    • Syclone#334
