sakroda
- 233
- 36
- May 3, 2016
İstanbul,
Europe
Hello everyone,
I have a 1990 AWD DSM running a 1991 ECU. Up until now, the car has been running perfectly with no issues, but recently it started leaving me stranded.
The problem is that while driving, the engine suddenly shuts off and the Check Engine Light comes on. I pull over and try to restart the car, but the Check Engine Light stays on continuously and the engine won't start.
I have a spare 1990 ECU, so I install it and the car starts immediately. Then I shut the engine off, reinstall the 1991 ECU, and it starts and runs again. However, I never know when it will shut off next.
One thing I noticed is that after switching back to the 1991 ECU, the engine usually shuts off again after about 3 minutes. After that, if I restart it, it may run normally again for a while before the problem repeats.
I also noticed that the MPI relay is making clicking noises when this happens. When i try to connect ecmlink it s not connecting to ecu at this issue.I don t get dtc code only light is on all the time.
Unfortunately, because of the country I live in, it is almost impossible to find replacement DSM parts. I do have an identical-looking MPI relay from a Hyundai. Has anyone tried using a Hyundai MPI relay in a DSM? Would it work, or could it cause different problems?
The strange thing is that I'm not even sure the MPI relay is actually the cause. Tonight I'm going to perform the factory service manual tests on the relay and wiring, but this issue is extremely frustrating.
I saw a pin i think it s pin 2 it melted the plastic inside of box.
Has anyone experienced something similar with a 1991 ECU in a 1990 DSM? Any ideas on what I should check next?
I have socketed by myself
