Street Build ITFLYS - 1Gina2G
ITFLYS - 95GSX 2.0L 6-Bolt Crank with 2G pistons, 1G TopEnd, with 2Gb-CamSensor and a Kiggly-CrankSensor - TD05H-Bastard 20G - E85 w 1000cc inj. ~25psi. Street driven track day car.
Gonna try this - wove ends of bare copper together and then flowed in some solder, trimmed down to a smooth ball, insulated and covered with a tough sleeve where the oem metal bracket could eventually go.
ready to install
Drilling out bolts is my favorite thing!
Harness ready for mock up so I can get the final length on the plug wires. The only thing left in my way are 2 snapped off bolts - the one I really need out is on the knuckle.
I’m feeling confident after reaching the M8 tap size 17/64 hand drilling with an old corded drill. I had a metal gasket to shield the axel boot from errant drill bits, and it saved me 3 times.
I started the work of setting the tap to work, with the sensor in place to ensure tap position and alignment. I got the tap to start and backed it out and removed the sensor. On putting the tap back in, finding the initial threads, I started to crank. After a few turns, I’d back it out to clean it and oil it
Then- snap - horror - disbelief - pleading - sadness, and frustration all in the span if 10 seconds.
and all attempts with pliers, and a well placed punch and tap with hammer yielded no reverse out progress. sofa king … bleh
They make a tool that slides down the flutes to remove them. Assuming they're not stuck. Maybe a few well placed pins could do the same?
  • Wanted 2g ISO Rear Pass EDM Tail light
    Looking for only a passenger rear EDM tail light for my 2g. Please lmk if you have one lying...
    • Gabriel Pena
  • Wanted 4G63 ISO built short block
    Looking for either a 7 bolt split thrust or 6 bolt
    • Gabriel Pena
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale 2g 1996 Eagle Talon TSI AWD
    I have a 96 Eagle Talon AWD standard tranny for sale. The car still ran when I parked it. I had...
    • eli1977
  • For sale 2g 2g front strut shock cup. MR103156. New.
    Mitsubishi Oem # MR103156 front suspension strut cup. New. Message 702-741-6987.
