Haltech TDC angle for Kiggly 12-1
dwdsm
20+ Year Contributor
588
45
Apr 28, 2005
Scenery Hill, Pennsylvania
What is the TDC offset angle for Haltech with the Kiggly 12-1? I seem to think it's 70 degrees but want to confirm.
Did you ever make progress on this? I emailed them about 6 months ago and never got a response. I will put a timing light on mine and figure it out when the time comes (my car is a long term project so it wont be cranked for a few more months), but having a starting point would be nice if its available. I tried to math through it all at work this morning but without a degree wheel on a motor in front of me, its a bit difficult.
Nope never did. I did get one response from Kiggly after three emails. And the screenshot they sent me said 450° on the haltech setting. That just muddied the water even more. I'm having some trigger syncing issues with the trouble code irregular trigger.. dunno but I've been stuck here now for weeks.
Here's my Kiggly 12-1, they set it up differently.
Which version are you using? The v3 12-1 says 105* on their item description which is where I ended up with my v3. v1/2 seem to be 70*. Was a little annoying to set up but now that it's set it works fine.
V3 Kiggly bought and installed over the Fall of 25. Receipt looks like 12 tooth w threaded puller holes.
