FIBA M - EC17PSE
Supporting Vendor
- 6,742
- 5,138
- Nov 1, 2008
Orlando,
Florida
When FIBA Motorsport designs something, it is never in halves and never to lower the quality of the final product. You get the best that money can buy – period!
These are the long-awaited, HIGHLY REQUESTED 2G DSM short shifter B&M replacements, but readjusted to our own design. Things needed to be tightened up to FIBA spec and while at it, we also tightened up some tolerances and changed the shaft design.
By virtually eliminating play in the shifter mechanism due to its dual bushings, this kit provides a highly precise, consistent shift feel for drivers who demand maximum accuracy. This will give you the best direct shifting feel going! You do not want to have a sloppy shifter… And this will bring back the very best in shifting for your 2G DSM.
Made with top-quality materials for strength, reliability and adjustability, this gives you the freedom for options later on, plus it’s fully rebuildable.
These will be the NEW pinnacle for DSM shifters.
These are going to be bolt-on to the factory shifter base and its lever arms.
This is a PRE-BUY product! These are NOT in stock right now! Pre-buy list closes on the 24th Jan 2026! Please allow about 1.5-2 Months for the production and then assembly + shipping, as with ALL pre-buys, You will be happy for the wait and get an amazing product as so many have before and will keep continuing the same results for you all!
PLEASE follow for your link to the site here! Sorry for the pictures on the site missing! Having server issues currently and will hopefully resolve them soon as pic's wont load up.
PRODUCT DETAILS
- Billet CNC Stainless steel 316 grade main shifter shaft for amazing strength and corrosion resistance
- Black coated for superior looks and subtleness
- High-strength pivot shafts for superior strength
- Billet CNC-machined Aluminum main housing
- Main housing Anodized gold for corrosion resistance and great looks
- Dual bronze bushes for lubricated movement, plus reducing unwanted play in the shifter with a wider load offered over the shaft
- New hardware for the shifter
- Removable shifter knob adaptor (stock M10x1.25 sized)
- Adjustable 2-shifting throw locations just like B&M
- Billet shifter boot upper surround will be available should you require a shifter boot to this specific design. Please see Jose Gonzalez’s page below in notes. He will make these custom boots to order to your specific specs for you upon request (separate charge, which is direct to Jose)
OPTIONAL EXTRA FEATURES
- Two shifter knob options available – both made from Delrin/Acetal for strength. This also stops the cold/hot touching issues that plague metal shifter knobs
- Longer shift knob for improved feel and grip with gel gear indicator on top (These are 70mm tall and a nice OD size for great hand grip)
- Short baseball like EVO style for that homely feel (These are 55mm tall and 44mm wide allowing a nice palm grip)
- Replaceable Billet housing pivot bushes should they wear out
- An optional Billet lower pivot bush is available, if required OEM P/N MB307949
- Removable shifter knob threaded adaptor can be replaced for a custom one, should you have a special shift knob that’s custom thread sized (custom adaptors not offered by me)
- Note: Custom billet shifter boot upper surrounds will be available via Jose Gonzalez – you can contact him through either his Instagram gbotb_upholstery or through DSMtuners Jose_gonzalez. These are newly designed shifter boots designed in partnership with Jose (separate charge, which is direct to Jose). This not only helps the FIBA Motorsport product out, but many smaller vendors and DSM freelancers are a key part of our community, so it’s great to help be a part of their growth and support/work with others where possible.
