  • Update Your Password Today!
    We have implemented tools to identify member accounts using insecure passwords and will be locking those accounts until their passwords are updated. Don't get locked out of your account - update your password today, and ensure your account has a valid email address on file. Read more here...
Please Support RTM Racing
For sale Freelancer ***** NEW PRODUCT ***** Active - NOW IN STOCK -- 2G FWD / AWD REAR EVO ARB adaptor brackets
£286.00
Status
2 members are watching this ad
Ad details
Hey all I have wanted to get these out for some time now but many projects have got in my way but here I am finally.
The reason I made these is the lack of bars available for the DSM! And everyone complains about the bars we have and don't have! So this opens up a whole different batch of parts and bigger/adjustable bars!
While i have explored blades and hollow bars the setup is not exactly simple and certainly not cheap! At all!!! So I have looked at every angle for you all while keeping costs in mind! If you consider the price of this setup vs just an RM bar its cost is low considering it is modular and has many options to choose from!
anyone wanting these and a set of OEM front arb brackets then here is the place to look for those https://www.dsmtuners.com/marketplace/open-new-billet-oem-front-rear-anti-roll-bar-brackets.2934/
WHAT TO THESE BRACKETS OFFER!
They allow you to run the stock Rear Evo 789 22mm anti roll bar as a direct bolt on to your oem or tubular subframe and suspension arms!
BENIFITS INCLUDE...
Overall stiffer Rear bar and a much better controlled rear end for overall better corner grip and precise steering.
SPECS...
OEM-------------------------biggest option currently available--------------------stiffness increase-----------------Evo 22mm stiffness increase
AWD oem rear 18mm------------------------------20.6mm------------------------------------------80%-------------------------------------150%
FWD oem rear 13mm------------------------------17.5mm------------------------------------------80%-------------------------------------180%
AS FROM 2022 I can now offer bushes for 24mm and 25mm bars that fit inside the same bracket! this means later on upgrading to a new size bar will be a case of buying new bushes and the bar only and NOT needing a new billet adaptor bracket! This is another WIN for me making my products work well for you cost wise and future proof your cars!!!
Very cost effective considering the RM bars are $200 alone and no choice of upgrades from there on.
So with these you can have many choices of upgrades
* They work with OEM lower arms and as seen my arms, should also work with Pauls also
They will be a direct bolt on for both FWD and AWD rear frames and will come with everything you need including new hardware bolts and bushes, all you need to buy is a used EVO rear bar! Should be fairly cheap! Just make sure its from a 789 as that's the 22mm version,
The brackets will also be black anodized for a stealth OEM look to finish the item off. If you want to use a bigger bar from the beginning and can get a used one let me know as i can supply the bushes in 24 and 25mm.
*** The brackets will all be CNC machined from T6 6082 billet aluminum
*** They come with bushes and all hardware ready to install onto the subframe and ready to fit to YOUR EVO ARB (Evo arb is not sold in this sale and you must buy a used one yourself!)
AWD / FWD bracket price is £286 shipped! Lower 48 US. Any where else please contact me. Canada is a bit more on average.
UPDATE!!! I NOW HAVE SOME STOCK OF POWDER COATED 22MM BARS READY TO GO!
CURRENTLY STOCKED ARE.
2X BLACK BARS
SOON 1X RED BAR
PLEASE ADD £230 PER BAR ONTOP. this includes the increase for shipping costs as its over 1 meter long it gets a fee added on.
while every effort has been done to make these USED bars look good again! Remember they are still used and will show some defects in the surface!!!
please fill this form in for ordering. Helps me in the long run. Once filled in either pm me for payment details or i will send you a paypal request shortly after receiving the form.
FYI
If these go well and sell then later on I shall be looking at producing new larger anti roll bars to my design and rating and I will of course make them to fit my brackets with bushes! so just something I wish to grow on and another thing for me to hopefully offer up to you all.
PLEASE NOTE!
* If you have the spare wheel well you must dink the back a bit for the evo bar to not foul the metal work on both FWD and AWD!
* These will also work on tubular subframes as the ARB mounting points will be in the oem location.
* You must buy your own anti roll bar from an evo. local or ebay is the best way to get this normally as most of those guys replace them for bigger anyway.
ANY QUESTIONS PLEASE DO ASK
These will be getting machined at the same time as the oem arb brackets so likely to start shipping out sept/oct 2022 as a current estimate.
Thanks Bobby
REFURBISEH BARS AVAILABLE! see above ^^^^^ if im out of stock then please message me.
IF ITS OF INTEREST LET ME KNOW BEFORE YOU ORDER AND I WILL SEE WHAT I CAN DO TO GET ONE AND IN A COLOR OF YOU'RE CHOOSING.
  • Like
Reactions: GSXbooster
Latest questions
REFURBISHED BARS ARE IN STOCK!
CURRENTLY HAVE 2 BLACK AND SOON 1 RED BEING WORKED ON!
IF YOU WOULD LIKE TO ORDER A BAR THEN PLEASE PM TO DISCUSS THIS PROCESS
Just to update this also. My spot has now come up and the billet blocks are coming in soon, these will be run along side the oem front and rear arb brackets and will be then sent to anodising. Once complete i can get them shipped out straight away.
Hardware and boxes are here for them to go straight out once back from the coaters.
  • Like
Reactions: fourgsixty3
Hi Bobby. These should work with any aftermarket EVO 7 8 9 rear bar including the adjustable ones as long as the appropriate bushings are used. Correct?
EC17PSE
EC17PSE
Just sell it once you got it all and everything, RM bars are always going to be wanted as a small upgrade option.
If you decide to got oem evo bar just keep an eye on ebay as they come up often or in the evo groups for a good price and can nab one.
If you do go bigger then oem evo just remember i do 24 and 25mm bushes only so anything bigger i cannot accomodate for.
fourgsixty3
fourgsixty3
Yeah, that's what I'm thinking. Keep the RM until the EVO bar is on. What would you recommend? 24 or 25mm? I'm thinking 24 should be plenty for a street car. Even the stock EVO bar should be more than adequate. I do like the adjustability of aftermarket bars though.
EC17PSE
EC17PSE
I mean i use a 22 stock evo and its fine for me. If you want the adjustability then opt for a 24 and that should be plenty for you for along time.
Boosted Fabrication ECM Tuning ExtremePSI Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com RixRacing RockAuto RTM Racing STM Tuned
