Activity Feed
Live updates
  • HyeToki replied to the thread 2G LC2 not reading in ECMLink.
    · 25 861
    Thanks for the reply Yall!I am currently not home to check the wires at the moment, but I do remember how everything was plugged in, and I made an outline showing exactly how everything was connected.I also want to mention that the car was...
  • pauleyman posted the thread Im in minneapolis in The Hangout.
    Anybody want to grab a bite and beer I'm here for 2 days. As long as you dont mind 50 up Gen x company.
  • dgdsm replied to the thread Power Drain after new Alternator.
    · 5 420
    There are some simple tests you can do with a multimeter to check for alternator leakage current. I have a similar situation, I replaced mine in June, but with an older compatible OEM alternator. I took it to O'Reilly's after cleaning it up a...
  • 92AWDHX40 replied to the thread DSM Shootout 2026.
    · 41 2,105
    Locked up and headed out thursday morning in my daily to meet my friends with dsm, getting towed. This year he isnt making it hes head to germany but goal get it to run on stand alone. Everything should go as planned. Plan to meet up with some...
  • pauleyman replied to the thread DSM Shootout 2026.
    · 41 2,105
    We need about 5 guys and rent an rvI would never have thought it would grow like this. My first Shootout was 96 and if I remember it was 88 cars.
  • jdxnc replied to the thread DSM Shootout 2026.
    · 41 2,105
    I'm 13h each way and have done it 10 times now, it's not that bad.Unfortunately this year will not be one of them, things just not working out on my end, too little time and work too busy.
  • oldmanfrost replied to the thread 2G Injectors not firing.
    · 19 547
    Yes checked pressure.. that was the first thing that was handled. Given power from outside source. To jump an injector with the plugs out , while cranking and fuel sprayed out the cylinder.Okay, I will test those two sensors.
  • diambo4life replied to the thread DSM Shootout 2026.
    · 41 2,105
    We should. 16 hour drive tho....:toobad::toobad::toobad:
    · 41 2,105
    Next year. OKC caravan!!!
    · 41 2,105
    Been in this game for almost 30 years and I have never been to one. Maybe some day...
  • Pushed posted the classified ad For sale AGT 52MM Bolt-On Turbo Setup in DSM Parts Classifieds.
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)$1100 OBO (Shipped PP G&S)Setup will be cleaned before hand, had a cracked drain pipe that leaked after doing some fab work-FP Cast Race...
  • ItsTwan309 posted the thread 1G Window motor/switch in Electrical Tech.
    My passenger window stopped working. Before buying a motor I wanted to test the switch. Does anyone know which pins to to jumper to see if it’s the switch?
  • jdxnc replied to the thread 2G Injectors not firing.
    · 19 547
    Yes the ECU relies on CAS and Crank signal to fire the injectors. Sometimes you'll get spark if one goes out, sometimes not but most of the time it won't have fuel if either signal is lost.
  • jesse12345 replied to the thread 98 Eclipse GS high school dream build.
    · 45 3,598
    I've been going hard at it these past few nights. I got the car wrapped in plastic and started going to town on the rust. The floor is fully complete which didn't take long at all. There were weird holes drilled that I had to weld up and paint...
  • SixBolt_16G replied to the thread 99 GST mechanical restoration.
    · 24 2,094
    Thats a good lookin' GST. 🤩
  • dwb replied to the thread 2G Injectors not firing.
    · 19 547
    Checked for fuel pressure? Any diagnostic codes?
  • all black 4G63 replied to the thread Haltech Coolant pressure monitoring.
    · 13 2,970
    So you run the sensor in the lower t-stat housing? I has mine there and could just rev the engine up and would see like 40-50psi. Are you running a t-stat in that motor? I must have something very strange going on. I borescope the cylinders and...
  • MikeyTsi replied to the thread 2G SRS diagnostics today.
    · 15 883
    Wanna loan me your scanner? :)I've been trying to find something that'll read the SRS code that I've got for like a year now and the MUT-II scanners have suddenly gone unobtanium/stupid expensive.
  • ItsTwan309 replied to the thread 33rd Annual The Shootout 2026.
    · 25 1,377
    You must be registered to see element.Done some upgrades to mine
  • ricardo118 posted a reply to a question on the classified ad For sale 2g eagle talon tsi 1997.
    honestly I'm not sure I was hoping the people here help find a good price for me and for you what are you thinking? as you can read is not it has its fair share of problems
