Activity Feed
Live updates
  • pma1123 replied to the thread DSM Shootout 2026.
    · 41 2,121
    I haven't brought a 4G car to the shootout in 15 years; I live 7 hours away and I still wouldn't miss it!Not having to worry about your DSM and actually enjoy the event.....Zero actual downsides to that plan.Its AOK to be a spectator...
  • Tony1094 replied to the thread 2G Car won’t start after being cleaned.
    · 30 1,535
    To my ear that really sounds like not all 4 cylinders are hitting. I'm also just trying to think of the most logical things that could be damaged by a pressure washer especially if not covered. I think injector connectors, MAF and maybe even...
  • ItsTwan309 replied to the thread Hood prop.
    · 16 616
    a 4' level ROFL Would love some shocks
  • 92AWDHX40 replied to the thread DSM Shootout 2026.
    · 41 2,121
    Oh yeah u remember hearing about that.
  • ItsTwan309 replied to the thread DSM Shootout 2026.
    · 41 2,121
    Shoot bring all the family haha.Enjoy your birthday!
  • steve replied to the thread DSM Shootout 2026.
    · 41 2,121
    I'm really torn cause it's happening on my birthday this year but I've got family coming here for the celebration on Saturday. Be safe and have fun. If there are any jet skis in the pool I want to see pictures.
  • Gabe92RTTT posted a reply to a question on the classified ad Wanted 1g 6bolt Balance Shaft.
    Thanks for that. Funny that ad is right there. I think I may have a line on one that a member is willing to donate one so I'll give that a shot and see if things are rotating smoothly. If not, I'll just delete them.
  • turbocrzed posted the thread Hood prop in Newbie Forum.
    Just wondering what everyone is doing to hold their hood up, stock prop rod, shocks, nothing I need ideas. What you have tried and what works. Post pics of you want
  • jdxnc replied to the thread Pet peeve.
    · 18 897
    I feel attacked lolIn my defense it's a drag only car that never sees the street now.
    · 41 2,121
    I’m always looking for a good deal on something😜
  • kyler021 replied to the thread DSM Shootout 2026.
    · 41 2,121
    I'll be there again this year, not with my car though unfortunately. Maybe next year :|. I'm hoping to buy a lot of parts while I'm there though so hopefully that'll make up for it.
  • CDgr97GSX replied to the thread 2G Fuel pressure fluctuation.
    · 62 2,196
    Thanks for all the specs! On the paper it's seems the fuel regulator it's on the limit. That was the reason I wanted to get some thoughts about this problem before I'm buying another 300$ fuel regulator. I will remove the fuel pump hanger and...
  • DSMPT replied to the thread 2G Fuel pressure fluctuation.
    · 62 2,196
    What about the voltage on the pump? I meant if you compared the battery voltage and on the fuel pump (supplied voltage) while the pressure is fluctuating.
  • Vladimir replied to the thread 2G Fuel pressure fluctuation.
    · 62 2,196
    I just looked at the numbers and it says that car off, 12v the pump produces up to 470 lph, that's about 125gal per hour or 2.08 gallons per minute. With alternator ON 13.5+ v it will flow 525lph. 525 lph is about 140gal per hour. That is about...
    · 62 2,196
    The voltage is steady at 13.8V. I can post a log later on today so you guys can see the voltage and the fuel pressure.
    · 62 2,196
    How does the voltage look like while the pressure is fluctuating by running the pump via ECMLink? Did you check for voltage drop at fuel pump and in ECMLink?
    · 62 2,196
    I checked the fuel pressure regulator and the diaphragm it's not damaged. I'm using a Fuelab 515 series and a Fuelab 818 fuel filter. I will send an email to Fuelab to get some feedback from them about the spring pressure and the overall...
  • miguelmcv posted a reply to a question on the classified ad For sale 2g Parts for sale.
    $1,900 with everything including trans, Tcase, flywheel and all bolts you will need for the fuel tank, rear subframe and shaft hanger bracket.
    Sorry bro, I can’t.
  • If you have the cable you can also capture data logs using Evoscan software for about $30. You use the ECUflash software to modify the data tables in the ECU and the Evoscan to monitor engine dataECUflash software is free but you will need to...
