Activity Feed
Live updates
  • Wun-jee Claud replied to the thread So what are you working on that’s NOT your DSM?.
    · 1,785 167,514
    Got the engine into the car today. Long tube headers and intake installed and solid (welded steel) mounts... Need to rebuild the 40mm dcnf carb next and change out the coupler in the Ford m90 supercharger... Inch by inch it's getting there...
  • 1990TSIAWDTALON replied to the thread Cam gear teeth damage, usable?.
    · 9 380
    I'd clean them with some dawn soap and water and an old toothbrush. They look reusable to me. Just a good cleaning is all. The belt should always be new tho.
  • 1990TSIAWDTALON replied to the thread 6266 Build or Bust.
    · 724 76,725
    I am very proud of your accomplishments so now its time for the reward......driving to get ICE CREAM 🧊 :thumb: ROFL
  • jdxnc replied to the thread What did you do to your DSM today?.
    · 12,065 829,389
    I didn't think this shell ran a 10 yet? :pBack from a 2 week vacation, the springs I ordered while gone showed up and I got to installing them.20 psi of spring isn't really easy to compress and install the bolts so I made a tool to compress...
  • jdxnc replied to the thread Bad injectors.
    · 1 181
    I'm not far from you, I have a set of 560cc.
  • pma1123 replied to the thread Just about finished.
    · 1 292
    Thats a really nice looking Glaspar you have; very nice work!!! I bet that turns heads out on the water!! I know I'd be giving chase to get a closer look!I'm a nerd about older boats too! :cool: Especially mini-speedboats, stuff with...
  • athlete3344 replied to the thread Cam gear teeth damage, usable?.
    · 9 380
    These came out of a different motor a while ago that had some sort of bearing failure or timing failure. The only thing im using is the cam gears out of that head.Did some forum searching and decided to use stock cam gears w hks 264/272 for...
  • rdeis replied to the thread General 1G DSMLink ISC has hysteresis?.
    · 8 480
    I have no intentional mods to the FIAV system. Coolant lines are connected to the throttle body.
  • pauleyman replied to the thread Cam gear teeth damage, usable?.
    · 9 380
    Thats physical damage from something. Best to find out what it was if you can so you dont repeat it
  • AndrexZ replied to the thread 3D Parts Discussion/Requests.
    · 67 6,038
    Has any one scan the 2G mid timing belt cover?You must be registered to see element.
  • dwb replied to the thread 1g timing.
    · 1 142
    The goal of a boost leak test is to pressurize the intake from the turbo inlet with slightly more pressure than your max boost. I use a tester "tool" that's made from a rubber coupler and pvc cap (from HomeDepot) with an air hose quick release...
  • steve replied to the thread General 1G DSMLink ISC has hysteresis?.
    · 8 480
    1> It's really two questions, it it blocked off or turned all the way in? When the car it cold does it fast idle until it warms up? You might not be able to tell if your idle speed never gets news the programmed setting (or 850 on a stock ECU)...
  • steve replied to the thread 1G Boost leak to valve cover?.
    · 6 331
    I haven't found a source that can be counted on. I keep testing and returning those that don't Others put a check valve inline.
    · 8 480
    Not really, no.Yes and yes.If I tighten it all the way down, the values start moving close to 3/4 turns out, which seems suspicious.My TODO list: 1> FIAV active (how to check?) 2> measure ISC coil resistance 3> Check throttle cable slack (I...
  • rdeis replied to the thread 1G Boost leak to valve cover?.
    · 6 331
    I tested the new one and it was "pretty good" but doesn't totally seal.Is there a source for one that seals, or do I just accept that as normal?Good to know, thanks! so it will leak less when properly warmed up.Yes, I normally test via...
  • TSI_Kyle_918 posted the thread 1g timing in Newbie Forum.
    Can someone point in the direction of steps of doing a boost leak test and also checking the timing. Assume I know little as a mechanic. I have ECMlink coming but have to do these steps first. I just want my car to run good.You must be...
  • Franck Talent posted the thread Bad injectors in Maintenance & Repairs.
    Hi guys, i need to buy new injectors on my Eagle Talon tsi 97 and i need 660 to you know where I can find it? I only found them on eBay but they are much expensive. On other site they are out of order
    · 9 380
    Thats what I figured! Just wanted to make sure I wasnt over thinking something. Thanks!
  • explicitgst replied to the thread RockAuto.com Discount Code Rock Auto Rockauto.
    · 181 47,326
    346418333306778927Good until August 28th. All is well in the world. I got a magnet with my last order.
  • ist dwa replied to the thread Cam gear teeth damage, usable?.
    · 9 380
    Hell NO
