Activity Feed
Live updates
  • 1990TSIAWDTALON replied to the thread 2G stuck in limp mode.
    · 79 3,016
    Is your PS wire attached to the sensor on the pump? It is there to help keep the engine going under a slight load, if it happens to dip down. Check that, its a single wire with a 90* round end. That is just for your dying issue when you turn the...
  • kyler021 replied to the thread ECMlink Another AEM Wideband Calibration Help Thread.
    · 38 1,646
    I will try to do that today and let you know! Preparing for a bad storm later.
  • ItsTwan309 replied to the thread Resolved New DSM P0300.
    · 82 4,622
    he wants you to look up how to do the pinout. He would rather you learn how to do it than you to misunderstand something he wrote. Its better to give the answer of what to check and let you do the research, if you are given all the answers you...
  • 1990TSIAWDTALON replied to the thread 1G 1g Automatic transmission mods to handle 800WHP?.
    · 16 826
    Good luck! :thumb: It takes A LOT to get to 800. This is just a calculated number, but its the most I have seen. My build is pretty healthy and $$$. Again though, this is just a #. The car is a handful to drive, I can say that. :)You must be...
  • ItsTwan309 posted a question on the classified ad Wanted 1g 1991 Black Cherry Eagle Talon.
    RixRacing just got in a 1gb black cherry
  • chrysler kid replied to the thread 2G 96 EU Oil pan temperature sensor.
    · 15 730
    I would not bother to replace the pan unless there is physical damage. It is better to save the old one, check for uneven surface when you have it removed and use a hammer to flatten the areas where there may have been dimples from over...
  • zippy22 replied to the thread 1G 1g Automatic transmission mods to handle 800WHP?.
    · 16 826
    I think before was running like 400 ish never got numbers but I’m planing on at least 650 and want to go to 800 and everything is ready it will just be changed by boost controller my car runs of of VE with ECMLink. I have a Kiggly flex plate and...
  • We're on Boost replied to the thread ECMlink Another AEM Wideband Calibration Help Thread.
    · 38 1,646
    If you do this lock in open loop thing, you should get a 3rd point while you are at it. A middle point. One where the gauge is reading somewhere around 14 AFR. Still in open loop. Then we can see how close that middle point is to being on the...
  • steve replied to the thread 2G stuck in limp mode.
    · 79 3,016
    That sounds like two different issues. The first is dropping RPMs under load like the PS pump. Does the same thing happen when you turn the lights on or hit the brakes? What about if you turn on the AC?The second is the throttle response and...
  • steve replied to the thread Resolved New DSM P0300.
    · 82 4,622
    While I don't care for either of the two battery terminals I don't see a problem with the charging system based on the posted voltmeter measurements. You might want to try measuring inside the car like at the ECU, OBD2 connector, or the cig...
  • GhostTypeP0300 replied to the thread Resolved New DSM P0300.
    · 82 4,622
    I’m definitely a little ruff around the edges. I see room for improvement but. Have potential. Like that Supra from F and F! LolI agree Dwb- I think I’m in denial Of the wiring issue because I don’t fully understand it but honestly would...
  • dwb replied to the thread Resolved New DSM P0300.
    · 82 4,622
    I trust the volt meter over this scan tool. However, I think it's pointing to a possible wiring issue. I'm not a fan of your negative battery terminal. Those wire clamp-type are notorious for poor connections and corrosion that still "look" ok...
  • bamatalon posted the classified ad Wanted 1g 1991 Black Cherry Eagle Talon in DSM Vehicle Classifieds.
    · 82 4,622
    lol thanks terminals look cleanOne day I will live up to the school moto- a professional technician the best of the best!
    · 82 4,622
    Yes I am considered a professional technician “the best of the best” I graduated from Ford, fact which is a top-notch electrical program.
  • pauleyman replied to the thread Resolved New DSM P0300.
    · 82 4,622
    Fair enough. I forgot what I did last week. Clean connections. Run continuity checks as necessary on smaller wires. On charging systems i find corrosion is the biggest issue.
    · 82 4,622
    The last picture I posted with the DMM was available voltage at the alternator B+ - forgot to do a voltage drop of that B+ to the battery negative? (Mod - Wrong, you test voltage drop from Alternator B+ to Battery Positive. You're looking for...
    · 82 4,622
    My apologies but this needs to be said. You went to UTI but don't know how to test wiring?For the larger gauge stuff its probably enough to just make sure the ends are clean and mating surfaces are clean. You can always test continuity and...
    · 82 4,622
    Can anyone give me step by step instructions on how to confirm that all wiring is good before removing the alternator thanks
  • 1990TSIAWDTALON replied to the thread RockAuto.com Discount Code Rock Auto Rockauto.
    · 181 47,408
    My front door is a SAMPLE of the orders I have placed. The tool boxes are also heavily "magneted" too ROFL My refrigerator went out and when the Lowe's delivery kids came with my new unit, they had to take that door off to get it in. It was at...
