Activity Feed
Live updates
  • GhostTypeP0300 replied to the thread Resolved New DSM P0300.
    · 82 4,627
    Batt. And alt.You must be registered to see element.You must be registered to see element.You must be registered to see element.
  • dwb replied to the thread ECMlink 98 GST Idle tuning.
    · 44 1,864
    Your ISCPosition isn't moving. I'd start by figuring out why.
  • James92 replied to the thread RockAuto.com Discount Code Rock Auto Rockauto.
    · 181 47,410
    This last order I made I got two magnets stuck together. My whole garage fridge is riddled with the rock auto disease.Poland? That’s dedication my friend; you’re a real one for that! I’m sure parts availability is difficult in those parts.
  • chrysler kid replied to the thread 2G First Gear Pops Out.
    · 57 2,917
    I fought with a trans with a first gear pop out for a few months. I replaced cables, replaced bushings, replaced cable ends, nothing made a differenceI was doing a final fluid swap and drained the new gold looking fluid into a clear plastic...
    · 82 4,627
    20v DC scale alternator b+ to battery groundYou must be registered to see element.You must be registered to see element.
    · 82 4,627
    Ok I went out and tried testing everything on the 20v DC scale!KOEO - engine offYou must be registered to see element.Koer - engine onYou must be registered to see element.Loads onYou must be registered to see element.Load on - rev...
  • So I took the car out last Friday night for a cruise night and 3rd was feeling a little goofy. I had admittedly missed 3rd pretty bad twice now which is weird for me but it happens.With the track coming up in a couple weeks I made the last...
  • pauleyman replied to the thread Resolved New DSM P0300.
    · 82 4,627
    Please stop posting all your google and AI results. Your posts are extremely difficult to read. Ask your question and we will answer. Before I even did any research I would've tested battery, cleaned and checked grounds, checked ALT fuse and THEN...
  • dwb replied to the thread Resolved New DSM P0300.
    · 82 4,627
    It never hurts to get the alternator tested. For piece of mind. *I* believe your alternator is ok but you have voltage drop somewhere. I'd start by making sure your grounds are tight, clean, and secure. Battery to starter bolt and firewall are...
    · 82 4,627
    Yes that's correct. You can google why there are two different settings and what it does.
    · 82 4,627
    Pauleyman?You must be registered to see element.
    · 82 4,627
    The alternator has two “modes” - low voltage/low load and high voltage/high load. The ECU controls which mode the alternator should be in using the “Generator G” pin on the ECU harness (pin 33). When G is grounded, the alternator is put into...
    · 82 4,627
    The DC voltage settings are on the other side of the meter. You're on batt test. Go select DC 20 volts
  • meciora replied to the thread RockAuto.com Discount Code Rock Auto Rockauto.
    · 181 47,410
    Code: 345497014302205698 Your code expires on August 14, 2026, 12:00 MidnightCT, so do not wait!I’ve ordered for now 8 times and I got 7 magnets. Maybe they appreciate the money I spend to ship them to Poland. Last item costs 100$ and ship plus...
    · 82 4,627
    Guys I also wanted to mention I used to have a 98 GST with this same code - P0300. It had a 1g CAS for some reason. It had no balance shaft I'm guess it went went out and took out the crank sensor they switched it or it had a 1g head I’m not sure...
  • DSMPT replied to the thread ECMlink 98 GST Idle tuning.
    · 44 1,864
    Do you happen to use a 1g CAS? If so, have you confirmed that the base ignition timing is set properly? Maybe it's too advanced? And if the idle RPM doesn't lower below a certain RPM by bottoming out the BISS, I would also suspect that the...
  • MindBlowin03 replied to the thread Anyone know the story on this car?.
    · 12 709
    I believe it's FWD, automatic and overpriced.Also seems to have the incorrect spoiler on it but I may wrong about that. Looks like the 1Ga Eclipse spoiler and I don't recall ever seeing that style on a Laser.
    · 82 4,627
    I feel like the alternator is going out do you guys approve of me taking the alternator out to bench test it or should I do some pinpoint test first thank you.
    · 82 4,627
    99Dsmer was saying to check the g control circuit first this is what I found online.It is best to check the alternator B+ circuit first. The B+ wire carries the actual charging current to the battery. If this heavy-gauge wire is loose...
    · 181 47,410
    346150917279045404 expires on August 21, 2026
