Activity Feed
Live updates
  • AirForcedDSM replied to the thread RM Racing 2G Sway Bar Interest Thread: 2021 Edition.
    · 116 19,918
    are these still being sold?
  • I pulled my ECU and have a questionable SMD cap under my 100uf 16v cap. I was going to replace my capacitors and also came across some stuff under my eeprom so I’ll need to investigate that but the SMD has me scratching my head. Insight from the...
  • Untuned420AT replied to the thread 420A Coilpack and spark upgrades.
    · 8 475
    Just made the draft. I haven’t been able to properly get a 1/4 mile and 1/8th mile yet so ill have to go test that soon when I get time(hopefully the bitc- I mean wondeful machine doesn’t break down on me)
  • ist dwa replied to the thread 1G Are FWD rack and pinions are the same as AWD?.
    · 20 7,562
    According to CAPS AWD 5spd racks are compatible with chassis, D21A (1.8L), D22A (FWD), and D27A (AWD). FOR AT cars there is a different part number and it is compatible with D22A and D27A.
    · 8 475
    Does it have something to do with my account being probationary? Theres no option to create a vehicle profile on my account
  • DSMPT replied to the thread What did you do to your DSM today?.
    · 12,067 831,567
    Correct. Manual vs Auto is 2g specific. The 2g auto starter's bendix gear stays inside housing and the 2g manual starter's bendix gear stay outside housing like the 1g starters.
  • tschuhly replied to the thread 2G stuck in limp mode.
    · 79 3,049
    I did before getting it tuned but not recently. I'll add that to the top of the list!Thank you for the reassurance with my engine health too!Sorry I forgot to respond to this as well. I bypassed my clutch safety switch because I was trying...
  • 90BCTalon posted the classified ad Wanted 1g 1990 Black Cherry Eagle Talon in DSM Vehicle Classifieds.
    I came to this website and specifically registered to find a rust-free Black Cherry 1990 Eagle Talon, AWD TSi - Manual transmission. It is what I had for my 2nd car back in 1996. I've always liked (to drive) these cars, Eclipse GSX too...
  • 1cleangsx replied to the thread What did you do to your DSM today?.
    · 12,067 831,567
    Right, again going off the part numbers and w4a33.com, the 2g starters are auto/manual specific, supposedly the 1g’s aren’t, obviously if you’re a 1g swapped guy with a 2g trans you’d want a 2g AUTO starter, I don’t know, I should be able to...
  • jdxnc replied to the thread 2G stuck in limp mode.
    · 79 3,049
    I meant it's extremely unlikely to damage the engine itself.Being the car is still running on the MAF, have you done a boost leak test? The stock MAF is very susceptible to air leakage issues which will cause sputtering/stalling etc.
  • jdxnc replied to the thread What did you do to your DSM today?.
    · 12,067 831,567
    It's possible, they do use a different flex plate between 1g and 2g.
    · 12,067 831,567
    You must be registered to see element.This is the starter off the 91 auto GSX I got my swap parts from, looks identical to my 5 spd one and according to stmtuned the 1g auto/5 spd had the same part # :idontknow:
    · 79 3,049
    Do you think this would cause my engine to stutter and maybe stall when taking off? Or is stall what you meant by kill?
  • techboy replied to the thread Techboy's 99 4G63.
    · 184 35,674
    Got these back from powder way back in Feb ... forgot to update the thread though. Pretty happy with how they came out. I left them sit stacked in the garage for the past few months, but I just dropped them off at a local speed shop to get...
    · 79 3,049
    No the CW bolt won't kill your engine, it can however cause of a lot of clutch engagement issues.From your log, the clutch switch shows -1 constantly, you did move the car and came to a stop but the clutch switch never changed, so something is...
    · 79 3,049
    I have an update for everybody! First let me say that I am completely new to, not only the DSM world, but the performance world as well. That being said, it turns out the rev limit seemed to be the issue. I didn't even realize that was a feature...
    · 12,067 831,567
    2G auto starters have a very short stickout, the gear barely protrudes the casing like so:You must be registered to see element.
  • 1cleangsx replied to the thread Project Jade Continutes.
    · 416 64,355
    Nice work Vic :rocks:
    · 12,067 831,567
    Okay last post on this in the hangout lol, the part# @steve referenced a few posts back, the md172861 is for a 2g auto, which I know IS specific to the 2g as according to w4a33, the 2g auto vs manual starters are different, on the 1g, according...
  • DsmDoomer91 posted the thread 1G Wheel offset in Newbie Forum.
    i put aftermarket wheels on my car and they stick out further on one side than on the other, how do I get better fitment
