Activity Feed
Live updates
  • pauleyman replied to the thread 2G Look for some helpful advice.
    · 9 608
    The above post is correct. Also that car is too far gone to repair vs its value. You can buy a whole car for less.
  • pottersgst replied to the thread 2G Look for some helpful advice.
    · 9 608
    Unfortunately this is not a actual GST this is either a GS or a RS. That's a non turbo motor in there, the 420A, and the engine mount location is the non turbo setup along with the computer setup.
  • My uncle has this 1997 Mitsubishi Eclipse GST that he said I could have if I fixed it up and I'm kind of lost since it will be my first time working on a car to this extent. It has the 4G63 engine with its internal forged to handle 11 to 1...
  • 1990TSIAWDTALON replied to the thread 1G Removing Rear Motor Mount.
    · 9 571
    I have the 1.8L info also if you need a picture from the manual. Just let me know. NP
  • FIBA M - EC17PSE replied to the thread FIBA Motorsport product updates 1G - 2G - EVO.
    · 126 27,076
    Some updates on the CTSV rotors and their details. This is now the last stage and I will start looking into a small batch of these for people. The Ducts i mention in the video will come a little later onYou must be registered to see element.
  • Boozer replied to the thread Saving a DSM Legend: 1998 Eclipse GSX Restoration.
    · 15 1,138
    10-4, sounds like a gameplan
  • Justin DuBois replied to the thread Street Build ITFLYS - 1Gina2G.
    · 1,732 228,830
    Patience pays off The right tool for the job You must be registered to see element. You must be registered to see element. You must be registered to see element.
  • Laporte18 replied to the thread 1997 GST.
    · 12 1,116
    So far, we've done a lot of maintenance on the car with new plug wires, coils, ptu, oil and filter, new sensors, new clutch master and slave cylinder. Changed out seized front brake calipers with new rotors, pads, and calipers. Re-routed...
    · 12 1,116
    I've already had a few of those WTF moments lol
  • tschuhly replied to the thread 1997 GST.
    · 12 1,116
    Dude!!!! Congratulations!!! Now you just have to wait until it randomly stops working in 2 or 3 weeks which is the tradition with these cars...lol jk
  • ItsTwan309 replied to the thread DSM Shootout 2026.
    · 41 1,966
    It wont let me watch the video. Hoping its the nasty little nt
  • chrysler kid replied to the thread Saving a DSM Legend: 1998 Eclipse GSX Restoration.
    · 15 1,138
    The cams are probably fine enough to verify the car runs and doesn’t have rod knock.With the scarring on them I’d want to pull the cam caps to see if there is any other scarring to indicate contamination in the oil system.Do the timing belt...
  • pauleyman replied to the thread Resolved Timing Mark On Exhaust Cam Won't Line Up.
    · 10 9,475
    Lose the cam lock tool. Clip the belt to the cam gears. I like office supply binder clips. Route the belt starting exhaust cam first, intake cam etc. If it doesn't match on oil pump rotate the sprocket ccw slightly. Same for crank. When you get...
  • ohyeah replied to the thread Resolved Timing Mark On Exhaust Cam Won't Line Up.
    · 10 9,475
    I know is way later but did this get resolved? I'm running in to the same issue. Even when I do get the plastic cam lock tool in place the teeth on my belt and my crank sprocket line up exactly and the belt won't slip on. I've tried everything I...
  • GzusEclipse98 replied to the thread Resolved Advice on Ignition parts.
    · 5 486
    Day after replacing the old parts and the car rides smooth again. No more tick and no more chassis-jerk when stationary. Spark plugs copper NGK BKR6E11, Coil Pack Hitachi IGC0147, and Plug Wires NGK 8103. I think i should edit this thread's tag...
  • GzusEclipse98 replied to the thread 98 Eclipse GS.
    · 11 2,248
    Maintenance Log: The following maintenance was performed at 65,2XX miles on the odometer. So as of yesterday 23rd of June 2026 the spark plugs, ignition coil pack, and ignition coil wires were replaced. Spark plugs were replaced with NGK copper...
  • GES replied to the thread 1G Removing Rear Motor Mount.
    · 9 571
    It's a 91 Eclipse GS, fwd, 1.8L, auto trans and it's the rear roll stop mount. That mount appears to be mounted on a long support member and wonder if that needs to be removed along with the mount.Thank you! 😁Thank you for posting that! 😁
  • bastarddsm replied to the thread DSM Shootout 2026.
    · 41 1,966
    · 12 1,116
    Finally after a lot of trial and error, we are up and running on a base tune. Still need to tidy up a few loose ends but we’re getting close. Was able to take it on its first drive in 8 years, up and down the street. You must be registered to see...
  • jersygsx posted a reply to a question on the classified ad Wanted Looking for an Evo 3 16g.
    I just listed a bad ass 20G built by Justin W, for about half of what a new evo 16g costs
