Activity Feed
Live updates
  • 19Eclipse90 replied to the thread 2G Fuel Pressure Solenoid.
    · 12 5,021
    MD113721 is the fuel pressure solenoid part number found in 2G turbo DSMs.I’m not sure how this thread could be any clearer.eBay is not what I would consider a reliable source for parts cross-compatibility.
  • Jeff D replied to the thread 1G Talon.
    · 56 5,139
    You must be registered to see element.Ended up just painting these parts over powdercoating as my oven setup had some issues. Anyway new wheel bearing in the driver side spindle and pressed the hub back on, I was really torn whether or not to...
  • Raider_831 replied to the thread 2G Fuel Pressure Solenoid.
    · 12 5,021
    Hello sorry this post is a bit confusing for me. I have a stock 1997 Eclipse GST Spyder. I currently have code p1105 which indicates faulty fuel solenoid.Can someone confirm which part number I need? I tried putting the MD113721 part on eBay...
  • We're on Boost replied to the thread Street Build Resurrection of the Red 90 Talon.
    · 849 84,004
    Marty it looks like you went another 500 rpm or so farther before shifting, and the boost held up during that time, and the airflow line goes off scale so we can't see it. What did the airflow get up to in there? The knock that you are wanting...
  • RamenPride replied to the thread 2G Throttle Body Sticking.
    · 30 1,489
    Don't mess with the throttle stop if it was fine before taking it apart. I would guess the nuts on the shaft are still too tight. I had the same problem on the last TB I rebuilt, and loosening them was the only thing that fixed it. They don't...
  • MHumphrey22 replied to the thread 92 Talon TSI AWD.
    · 4 385
    Installed some of the rear plastic and rear speakers last night.
  • 19Eclipse90 replied to the thread Spyder Interchangeable.
    · 2 228
    I imagine the OP is asking about the window switch bezel which, almost certainly, won’t be found new anywhere.OP, you can try this avenue:You must be registered to see element.
  • FIBA M - EC17PSE replied to the thread 2G Throttle Body Sticking.
    · 30 1,489
    I only see 1 spring latching onto the arm. maybe the video was not clear for me to see it correctly, I just see the green one lol
  • chrysler kid replied to the thread What did you do to your DSM today?.
    · 12,087 832,574
    Not joking; I broke atleast 4 different chain breaker tools. There was no way to get the bottom one out, I even used a torch to make the pin glow red and it was still not moving even with a mini sledge.Go at the pin with the drill from the...
  • kyler021 replied to the thread 2G Throttle Body Sticking.
    · 30 1,489
    There's 2 springs on there. It was one green one which is the internal smaller spring and the one on the outside. Both were clipped into that groove thing where the throttle cable attaches to.Hmm.... Is the outside spring supposed to be wound...
  • enriquez2000 replied to the thread Street Build Resurrection of the Red 90 Talon.
    · 849 84,004
    I think i did the tune on this... if it was my work its still not perfect.I bet it hit hard Marty!
  • miliman13 replied to the thread Street Build Resurrection of the Red 90 Talon.
    · 849 84,004
    7.5k Rpm with 30psi at WOT and 13.4° of timing and less than 2° of knock !!!!!!Wow 😮 you don’t need boost just more mixture and you can slightly up the timing yielding significantly more - power train exploding power lol.Very nice - thanks...
  • dwb replied to the thread Spyder Interchangeable.
    · 2 228
    According to ASA, any 2g window fits - MR264297 I'm not sure what a lock control panel is. I can look that one up too with a better description or maybe a pic.You must be registered to see element.
  • MindBlowin03 replied to the thread Street Build Resurrection of the Red 90 Talon.
    · 849 84,004
    That's pretty good airflow for 30 psi. Definitely needs more boost once that meth is ready.
    · 30 1,489
    Why do you only have 1 spring on that? you should have two springs. one internal to the white plastic and one external to the plastic, you seem to only have 1 external spring
  • SixBolt_16G replied to the thread What did you do to your DSM today?.
    · 12,087 832,574
    Unfortunately attempt #3 of trying to remove the shift lever pins so i can replace the oil seal was unsuccessful. I used a mini torch to heat them up, then tried the mini air hammer and another chain link removal tool. Still not budging.At this...
  • Momma of 2 posted the thread Spyder Interchangeable in Maintenance & Repairs.
    I have a 1999 Mitsubishi eclipse spyder convertible and I am looking for a drivers window and door lock control panel. I am not having any luck finding one. Does anyone know what other vehicles will interchange with it?
  • 1990TSIAWDTALON replied to the thread 2G Throttle Body Sticking.
    · 30 1,489
    Your return spring wiggling sure looks like it wasn't rewound the correct amount of turns but it might just be the video. Is th throttle easy to open? Does it "snap" shut when you let it go back to the idle position?
  • FIBA M - EC17PSE replied to the thread FIBA Motorsport product updates 1G - 2G - EVO.
    · 126 27,131
    1G AWD rear diff support are part of the new 1G developments.This mid section was made in sections to make it easier for printing and also price lol. The end item will be 1 piece for the central bar. The ends are still bolt on due to that parts...
  • 2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must be registered to see element.You must be registered to see element.You must be registered to see element.You must be registered to see element.
