Activity Feed
Live updates
  • jdxnc replied to the thread What did you do to your DSM today?.
    · 11,896 749,780
    Mine is a racecar, everything rattles, so everything gets loctite lol. Two of my friends had their crank bolts come loose within the last 3 weeks.I've been tidying up the last little things before first startup, for my oil feed line I decided...
  • Hey all, So after a 7 year restoration we back together and driving. I have a fresh out of the wrap TMZ stage 3 trans filled with Amsoil MTL (tells you how long ago I had that rebuilt...), resurfaced ACT Streetlite, and new ACT 2100 clutch. New...
  • dwdsm replied to the thread The 4G63T PCV System.
    · 16 196,231
    I currently have a Frontline Fab valve cover to run 8an lines. But before that I had two 6an bungs added to the factory cover to run to the catch can and back to the intake with a 8an. That's what it pretty much was forever until I started a...
  • explicitgst replied to the thread 2G Low Oil pressure.
    · 25 2,048
    Thank you all again for the input!I took my bumper off this morning, lowered the adapter below the OFH, and opened up a port, 4 air bubbles came out. I let it sit in a little container for a few minutes, but it was just the 4 bubbles that came...
  • jesse12345 replied to the thread Neglected 95 Eclipse GSX nostalgia build.
    · 360 33,135
    A little update on the car as I've been driving it this past week. It's been an absolute blast! The 14b pulls very well and has absolutely surprised me. I dialed it all in on link very easily. This is the first ive tuned with the maf and it wasnt...
  • We're on Boost replied to the thread 2G Low Oil pressure.
    · 25 2,048
    Yes this could happen, especially if his AEM sensor is the 150 psig one, because the 150 psig sensor will have less resolution at these low pressures. Also, the sensors AEM gives you in the kits are the brass ones which they only rate at 3%...
    · 25 2,048
    Well, the filter/restrictor FP sells for journal bearing turbos is 0.125" ID. They call it the "Full Flow" size. I just measured the ID of some Vibrant -4AN fittings that I have here (part numbers 10771 and 10781) and they are only 0.168 ID in...
    • 2g DSM oil pressure at idle spec from the FSM pg 11B-3  is 11.4 psi or more at 750 rpm warm idle.jpg
  • DSMPT replied to the thread What did you do to your DSM today?.
    · 11,896 749,780
    Agreed. I have had metal solid mounts on my 1g for many years, I like the shift feeling but I won't do this on a street car. Yes, it requires to check for loosen bolts and nuts often. I have experience that all the lock bolts on adjustable cam...
  • 1cleangsx replied to the thread What did you do to your DSM today?.
    · 11,896 749,780
    I gotcha, I always like to double check fasteners as well, I just wanted to avoid excessive vibrations as much as possible lol
  • diambo4life replied to the thread What did you do to your DSM today?.
    · 11,896 749,780
    I am doing a Saturn alternator swap currently.
  • DSMPT replied to the thread 2G AFR and idle changing when braking or headlights on..
    · 2 267
    I would suspect voltage drop first.
  • enriquez2000 replied to the thread What did you do to your DSM today?.
    · 11,896 749,780
    Ive never had a problem other than vibration......until I did... i bolt check the usual suspects in the bay like alternator bolts and what not but now I will warn everyone to loctite their timing side heavily!
    · 11,896 749,780
    Another reason I’ll never run solid motor mounts on my car. I don’t understand why they’re as common as they are on street driven cars. With a Fluidamper/stock engine mounts, sitting in the car you’d never guess the balance shafts were deleted...
  • Imback replied to the thread What did you do to your DSM today?.
    · 11,896 749,780
    That's odd i've never had issues with my bolts coming loose. Only time i had an issue was when i didn't torque one to the correct #
  • DSMPT replied to the thread 2G Low Oil pressure.
    · 25 2,048
    Agreed. And another possibility, could be the junction block still has the air trapped inside and causing the pressure sensor reads improperly. Did you check by locating it below the OFH?Also you should confirm this. You said you have a oil...
    · 11,896 749,780
    Please make sure you use a lot of loctite on your timing components. I just found out that my vibrations backed out my timing pulley... waiting to find outnif I got blessed or if my valves bent
  • Imback replied to the thread 2G Coil on plug set up.
    · 6 294
    yes
  • Ludachris replied to the thread Turbo Tom.
    · 8 1,725
    I removed the last several posts because they detract from honoring Tom with this thread, which was the intention here. Hopefully everyone can respect that.
  • TerminalTalon replied to the thread 10yrs as a DSMtuner....
    · 51 3,599
    April 2006. I must have bought the car and joined right away.
  • jmt2028 replied to the thread 2G Coil on plug set up.
    · 6 294
    Even though that kit came from a 1g, it should still have 5 pins in the single connector correct?
